Question about Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp
I get power but no sound from subs.
  • 1,056 Answers
Do you get sound if you set it on full? If you don't get sound in any way it maybe broked. Do you smell burnt components? Is the protection light on? If so you probably have a shorted transistor inside. If everything looks normal but has no sound at all. The preamp circuit is probably not getting power due to a malfuctioning power supply circuit. The way a car amp works is it has a DC-DC converter, which steps up the 12 volts to two supply voltage. One is usually a -35V, an the other is +35V. To a totall of 70V. Power transistors don't operate efficiently on 12 volts thats why it is designed like that. A PWM (pulse width modulation) circuit which consist of a chip, and various components connected to it drives an array of Power FET(field effect transsitors) usually conected in parallel to add power. These FET drive two or more "powder iron core" transformer. The other side of the transformer is connected to large diodes, providing power to the transsistors that actually drive your speakers. The supply voltage to the section preamp section is usually the same as the battery voltage. This preamp section filter high frequency for things such as low pass, high pass etc, and through many stage of amplification using small transistor, the final stage is the large transistors that drive the speakers. If you can tell me more info I can help you with a step by step guide on fixing the amp.
Posted on Jun 28, 2009
I just got my system today. All the speakers are working, except the sub-woofer. Any ideas what could be wrong (if not DoA)?
Did you connect power to the sub-woofer? Most subs have their own amplifier. Just check if there is also an on / off switch on the sub.
Apr 18, 2015 | Frisby 5.1 Surround Sound Home Theater...
I have a mono block kenwood amp and a type r sub their is no sound to my sub but there is power to the amp just no sound
Check your subs impedance to establish speaker is working ,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 06, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
Red light constantly lit, no sound
Would be surprised if this blew the sub of it was off at the time, have you tried the sub with another input source? Is it the clip light or the power light that's on?
Nov 01, 2013 | Behringer Truth B2092A Powered Subwoofer
PROBLEM WITH SUB WORKING ON A PIONEER VSXAX5I RECIEVER
The problem is in the powered sub, the buzzing sound is caused by one or more defective audio output ic's that drive the subwoofer directly, service is the only option to remedy the situation.
Apr 14, 2012 | Pioneer Audio Players & Recorders
Adding Subs to a Bose 901 system
The Bose system has sound that is unmatched, the 901 with the equalizer is amazing. I have done what you are thinking of doing, the speaker runs 5ohms giving more power to the coils, adding a sub will color the sound and will not give the desired results, the 901 equalizer may be damaged with the modification of the sub, not recommended.
Mar 06, 2012 | Bose 901 VI Main / Stereo Speaker
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
just go through ur connections man one by one ull find the prob soon.....check teminals on battery...power line to amp ....all fuses within prob area and obviously make sure u have a good ground.....really impotant.....ground is the most neglected thing people do from my experience bein a audio tech oh and if that isnt it check ur subs....stick a 9v batt on the back pos n neg of each sub n c if they pop in r out this will determine if ur subz r blown
May 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
428 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
