Question about Wahl Magic Clip Clippers Hair Trimmer
Wahl magic clip clippers are very noisy , tried to adjust ?
I just purchased these clippers and they worked fine until last night , they started to chatter very loud and so i adjusted the voltage screw on the side but they just won't quiet down. any suggestions?
  • 30 Answers
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
Posted on Sep 21, 2009
    Problem Solver:
  • 12 Answers
Have you oiled them?
Posted on Aug 11, 2009
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
Jul 30, 2011 | Wahl Health & Beauty
Runs if tipped to the right. Not if tipped to the left
check the electrical cord at the clipper connection by bending the electrical cord at clipper end with the clipper on if the clipper stops the electrical cord is broken in side.if this will dose not locate the problem, the next possible problem will be the coil inside the clipper the coil has a broken field winding wire. Have a Wahl clipper repair shop repair the problem.
Mar 30, 2010 | Wahl Magic Clip Clippers Hair Trimmer
My wahl clipper is very noisy, what should i do to fix the problem
First, they need to have a drop of oil put on the cutters every time they are used. Second, there is usually an adjustment screw on the side of them to adjust the travel of the moving cutter. Adjust that so that it completely goes across the slots in the stationary one, but not too far or too noisy.
Nov 24, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Replacement guards for wahl clippers
Where abouts are you? Generic salon supplie stores have these, but most will only sell directly to a salon. Talk to your local hairdresser and see if they will order them in for you.
Nov 03, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Sep 16, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Jul 21, 2008 | Wahl Designer 6 (8355100)
Health & Beauty Logo
4,055 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
