Question about Whirlpool Dryers
Whirlpool senseon electric dryer won't start
Whirlpool senseon electric dryer (model #GEX9868-JQ0) would not start when start button was pressed. Opened back and removed wires from thermal fuse and shorted them together, dryer started fine. So I replaced both the thermal fuse and the thermistor. The dryer ran for two days and the same thing has occurred again, dryer won't start. Any suggestions on what to do next? The vent and inside of the dryer look pretty clean to me.
Thanks,
Chris
vest6
  • 196 Answers
SOURCE: Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Posted on Jan 26, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
Posted on Jan 21, 2009
  • 686 Answers
SOURCE: Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Posted on Mar 20, 2009
  • 15 Answers
SOURCE: dryer won't start
IT SOUNDS TO ME AS IF YOU HAVE A BAD DOOR SWITCH. YOU CAN TRY JUMPING THE SWITCH OUT TEMPORARILY JUST TO SEE IF THE UNIT RUNS.
Posted on Apr 07, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a gas whirpool senseon dryer model number
Hi, If the ignitor glows and then shuts off before you get a flame, then you will need to change the coils on the top of the gas valve. This is the most common problem with the gas dryer not heating consistant. Make sure your venting to the outside is cleaned out. A plugged went causes the coils to go back quicker.
I hope this helps and please let me knw if I can assist you further.
Thanks
Vic
Posted on May 11, 2009
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 21, 2017 | Whirlpool Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
Oct 18, 2011 | Whirlpool GEX9868J Electric Dryer
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool Imperial Gas Dryer (Model:LGN2000.JQ0) where the heat will intermittantly go on or stay off. Can you let me know what would cause that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Whirlpool GGQ8831L Gas Dryer
My COSTCO Whirlpool dryer SEDS 800 JQ0 heats but won't tumble.
There is usually a friction drive belt inside the unit that turns the drum. Check for a broaken belt or a defective drive motor. Usually it is just the belt.
Jun 20, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryer will not start
Check the following:
Is the power cord plugged in?
Has a fuse blown, or has circuit break er tripped?
Was a regular fuse used? Use a time-delay fuse.
Is the dryer door firmly closed?
Was the START button firmly pressed?
Is a cycle selected?
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Clothing dryer whirpool senseon ulitmate care 2
Chances are you have tripped a thermal fuse and that needs replacement .. Once that opens ( electrically).. the heater/blower and tumbler will not cycle.. here is a link that wil help you identify the parts on your dryer that you may need.. Pay particular attention to any and all thermal sensors and cut off fuses ( Items 7,8 & 9 ) On Section 03 at this link...
http://www.pcappliancerepair.com/model-display.php
Chances are its the thermal fuse that failed and needs to be replaced.
Hope this helps..
Aug 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
