Are you asking about the rubber door boot/seal??? The outer edge is held on by a spring loaded wire that runs around the door opening. You can see it if you lift the outer edge of the boot close to the painted cabinet front. The inner edge of the boot is help on by a very big hose type clamp. Some models you can get to it through the opening after you remove the outer wire. Some models need the washer top removed to get to the clamp screw.
Hello saguilar891 - Generally speaking, the model and serial numbers on Frigidaire front load washers are located on the upper front, as you open the door.
Hello Friend, thank you for your inquiry! I see that you have a Frigidaire front load washer; however, please help me understand what you are referring to. Are you speaking about the gasket? Is the gasket damage or are you seeking instructions on how to remove/replace it? With this information I can better address the issue at hand. Thank you! - Z
remove and clean door gasket
