Question about Cell Phones
Playing music on my verizon phone
My lg vx8300 will not play the music i download to an sd card from windows media player or verizon music essentials software . I have no problem loading the music to the card but the phone says "no content" and yet memory shows the files are there
5 Suggested Answers
SOURCE: saving songs on sd memory card
1. Put a micro SD card into your phone. (Make sure it's blank)
2. Format the card from your phone. To do this go into "Menu//Settings & Tools//Memory//Card Memory" then click on "Options" that should open the format screen. Enter your security code (usually the last four digits of your cell #) and format the card.
3. Exit all menu screens by pressing the "End" button and remove your card.
4. Insert your card back into your PC. It should recognize the card and open a "Removable Disk" window. (if not, manually open this window by clicking on "Start//My Computer//drive E: or F:" , they might vary depending on your computer set-up.
5. You should see a folder named "my_music". That's where you are going to drag your music files into.
6. DO NOT open any media player. Just find the location of your music FILES. Usually if you click on "Start//My Music" your music FILES will be stored there.
7. Simply drag and drop music FILES into the folder that I listed on #5. DO NOT drag an albulm. It won't work. Just the music file.
Posted on Feb 04, 2008
SOURCE: not able to play music from sd card on env2
take all the songs out of their folders on the sdhc card. i thought mine was broken till i figured i should try it
Posted on Apr 28, 2009
SOURCE: microSD does not contain supported music files
1. Install the sd into the phone.
2. Go to Menu > Settings > USB > Mass Storage
3. Connect the MotoVE240 to your PC via USB
4. Under My Computer open drive (E:).
5. Find the folder that has your music in it. Example: My compter made a folder called Music.
6. Drag music from that folder to the my_music folder. (the phone will only read music that is in this folder.)
7. remove your phone from the usb
8. press the music note on your phone and enjoy your music
Posted on Aug 08, 2009
  • 88 Answers
SOURCE: I cannot play music off my sd card on my lg banter phone
i think you need to re-program your phone
i hope in can help you
Posted on Sep 06, 2009
  • 80 Answers
SOURCE: Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Posted on Jul 11, 2010
0 characters
1 Points
Sep 06, 2009 | Cell Phones
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
I have downloaded music from Media Player to phone but it is all in folders so I do not get continuous play.
No you dont use media player. you gotta take your micro SD card and you need a card reader. these things arent too expensive. you can buy them at futureshop, best buy. basically any electronics store wil carry them. computer stores are the best for this. take the card put it in the card reader and stick it in your computers USB input. now open up the card in my computer, and drag your music into the my music folder. Now your done. just take the card out of there, and put it in your phone. you will be listening to the music in no time.
May 13, 2009 | LG Shine KE970 Cellular Phone
Can't play any music
chances are your driver on your pc is corrupt. uninstall your driver from your pc for your phone then re install it. then go to verizons web site to see if there is an update for your device and download and install on your pc. delete all music files on the sd card( i know this is not probably what you want to do but chances are the music files are corrupt as well.. after you do all of these steps sync the phone to the pc and download one music file to the phone go in your applications page on the phone find the file and then transfer it to the sd card. remove the usb cord from the phone then play the file on the phone it should work properly
Apr 18, 2009 | Verizon Communications LG VX8350 Cell...
Phone not reading music on LG enV from memory card....
i had the same problem with my original "the v" you may want to check the file type. If you have wma files, you should try converting them to mp3 or vice versa. research to see what file types your phone supports. I had to take mine into the verizon store to have them update the software on my phone to be able to play mp3 files.
Feb 19, 2009 | LG enV VX9900 Cellular Phone
Putting music on an LG Scoop.
I believe these phones will only use a 512kb memory card. I could wrong. The phone directory may only hold 30 songs. There may be a limit on how many songs and how much memory the phone will hold.
Jan 14, 2009 | LG VX8300 Cellular Phone
The songs should be stored in the compact able format of the phone ,check the manual of the phone and you will get the formats....and store the in the format you be able to play.........
May 19, 2008 | LG VX9800 Cellular Phone
Saving songs on sd memory card
try just sending music from your pc to the memory card
Mar 27, 2008 | Motorola Mobility i870 Cellular Phone
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Music player and micro sd card
I have found that mine didn't recognize songs if the name of the song was too long. Try going into Windows explorer (with the micro sd card in the computer) and rename at least one of the songs as a test. If that song is recognized by the phone, go back and shorten the names on the rest of the card. Good luck!
Sep 23, 2007 | LG VX8300 Cellular Phone
Cell Phones Logo
122 people viewed this question
Top Cell Phones Experts
IT Solution
IT Solution
Are you a Cell Phone Expert? Answer questions, earn points and help others
