Question about Kenmore HE2 Plus Front Load Washer
Spin speed flashes and beeps randomly thru out wash cycle
Upon turning power on HE2 Plus Front Load Washer, the spin speed flashes back and forth between all three speeds and doesn't allow user to select one over the other. Continuosly flashes and beeps. When finally stops on one, you can no longer toggle between all three. After pressing start, the beeping starts randomly throughout wash cycle. Clothes are fine, whole cycle completes but would like to stop random beeping and allow selection of spin speed prior to starting load. Thank you.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
My he2 kenmore clothes washer does not go into spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer that does not drain and spin well. It does drain and spin sometimes though, so nothing is preventing from doing that. The service tech replaced the pump, but he could not fix...
Some how there is debris like socks or something small getting down and blocking your drain plug. take the bottom panel off your machine by removing the 3 (1/4") screws at the very bottom of your washer. once the panel is removed you'll see a 1 1/2" PVC white valve plug. open that by turning it to the left untill open (WARNING ALL THE WATER WILL DRAIN OUT THOUGH THIS PLUG) remove debris and you all set.
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Does anyone know the code to make a HE2 Plus "spin only"?
select the Spin/Drain cycle. any special code would have been the service/diagnostic mode but that wants to run a factory test which involves water fill and agitate
Apr 28, 2009 | Kenmore HE2 Plus Front Load Washer
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
125 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
