If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
SOURCE: ELECTROLUX EOD5310
there are two fans and one is out of sight and is to cool the casing. normal for the casing fan to run for up to 20mins after switching off. after 4 years, maybe getting a bit worn and hence noisy. nothing to worry about
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
SOURCE: After cleaning the top half oven with a self-clean
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
