Question about PNY 2GB microSD Memory Card
The card is there, but it's not being read
When i put the small chip into my phone it says memory card has an unrecognized format. when i hit yes to make it reformat now, it says error then memory card does not exist. i have ringtones on the chip. what do i do?
  • 1 more comment
  • ariellek258 Jun 28, 2009
    how do i format it?
  • ariellek258 Jul 12, 2009
    i have an at&t SGH-A737. i got my phones from the website www.ventones.com. i saved my ringtones to my computer and then put the ringtones on the chip to get them on my phone. i haven't formatted the chip. i try to, but for some reason it won't let me.
  • steve drzewiecki May 11, 2010
    i need to know the type of phone and how you got the ring tones on the chip and did you format the chip with computer ir the phone
    Scholar:
  • 136 Answers
The MMC cards should always be formatted to suite the file system of the device, so its recommended that you format the MMC card using the device on which you want to use it.If you formatted it using a PC you must select the appropriate format while formatting it.
Posted on Jun 28, 2009
I cant reformat my phone memory in my motorola w388, i try to follow the steps to master clear but it still unable to work. is there something i can use to reformat my phone memory??its getting worst
hi!
All you have to do to reformat the memory card is that you have to
insert the memory card, press the Center Select Key,scroll to and select Phone Status, scroll to and select Device Info, scroll to and select Storage Devices,select Memory Card and press Options, and then select Format.When prompted, press Yes to continue or No to cancel formatting.
Another step for you to be able to reformat your memory card is you just have to
press Main Menu,scroll to and Select Settings,scroll to and Select Storage Device,scroll to and Select Memory Card,scroll to and Select Format Memory Card, and then
highlight Yes and press the Center Select Key.
And this will also be an option for you to format your memory card.Here are the steps:
Insert the microSD card.
Press Menu > Settings > Security.
Enter your lock code.
Select Format External Memory. (A warning will be displayed.).
If you are sure you wish to remove all the files from your microSD card, select Yes (left softkey).
Thanks!
Apr 17, 2011 | Motorola Mobility W388 Cell Phone
I have an samsgha707-e4rd-att with an 8GB micro SD i downloaded music on it and when i go to use it it says memory card has an unrecognized format reformating will erase all data reformat now reformat now...
according to this article http://www.tech-faq.com/samsung-sync-sgh-a707.html I believe it will only go up to 2GB. That or the music files you put on there have to be in a different format. Most likely the first option though. Hope this helps, be sure to rate how i did
Apr 06, 2011 | Cell Phones
My cell phone micro sd card says memory card has an unrecognized format and that reformatting will erase the data what do i do and how do i reformat and not lose the data i don't know how to reformat
Do you have a memory card reader for your PC, try to borrow one from a friend and check if you can read data off the card. If you can then make a backup of the data and then format the card to FAT32 as i think you have formatted the card to NTFS which is a file system native to windows and will not work with mobile phones. The best option would be to format the card on the phone itself after data backup as it will assure compatibility with itself.
Jan 21, 2011 | Electronics - Others
My phone can't read the memory card.it gives me this message (memory card has an unrecognised format. Reformattingvwill erase all data.
If the memory card worked before with your phone, then suddenly became unrecognized, then the memory card probably got corrupted.
The best thing that you may try is to insert the card to another phone and connect it to a different computer. There are times that another computer recognizes the card with this kind of problem.
If a different computer recognizes your card, immediately back-up the files, then reformat your memory card. However, if the same problem occur on different computer, then there's nothing that we could do but to reformat it.
Whether you reformat it or not, you could no longer recover the files if it's still unrecognized.
Thank you and good luck!
Jun 25, 2010 | Computers & Internet
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
Memory card
take out the memory card and put it in a card reader And reformat the card from comand promt that should fix it. TYPE ON RUN CMD an black screen type:  FORMAT /F  C:  THE C: IS THE LETER OF YOUR HARD DISK BUT INSTEAD OF C: PUT THE LETER OF YOUR CARD COULD BE E: F: AND SO ON.IF THAT DOES NOT FIX IT TRY ON THE COPMUTER MANAGEMENT, I HAD THE SAME PROBLEM AND IS OK NOW .
Sep 30, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Help
You can try formatting the memory card on your computer if it came with an SD adapter and your computer has an SD slot. If not I would recommend having a friend reformat it on their phone, OR you could bring it to your service provider and see if they can reformat it for you.
Jul 11, 2008 | Cell Phones
Reformat
for formatting d phone memory like 6600,3230,7610,6670etc type *#7370# and then press yes..then see d results
Dec 03, 2007 | Nokia 6600
Samsung t629 memord card problem. PLEASE HELP!
ok, I have managed to use my sandisk 512mb card to put on music...even though I didnt know you had to format the disk in phone first (I dont recommend because all my music is individual clips and not in my music file), however once you see that the music is on the card via "my files" I went to the music player and hit options...then hit "add music from" then hit "memory card"...now you must put a check mark by all the music files you want to add to the music player (or choose "all" and hit ok) This will put your chosen songs off your card into the music player and you can see the song title at the top of your player screen and use the arrows to move through your songs/clips. Choose the song and hit play.
Oct 29, 2007 | Samsung SGH-t629 Cellular Phone
My stuff
Do you have a card reader in your pc that you can put the card in?  And of course the adapter to convert microsd to sd card size?  If so then just put the card in pc, right click on the icon when it appears in your "My Computer" folder, left click "format" and format the card there.  It's possible that the data on the card got corrupted somehow and maybe why the phone is having trouble reading or reformatting it.  If the card still doesn't seem to work after putting songs or pictures on it, try using the card in a compatible mp3 player or a friend's phone with a microsd card to see if the card works, if it does then the problem is probably with your phone.  I have heard about compatibility problems with some phones and certain brands of microsd cards, not sure if this is one of them.  Hope this helps.
Aug 24, 2007 | Samsung SYNC SGH-A707 Cellular Phone
PNY 2GB microSD Memory Card Logo
343 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
