I lost my verizon stb remote which automatically controled the stb. I have a universal remote and need a code for the motorola-brand fios stb. If you have a code I would greatly appriciate your help.
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: philips universal remote codes for symphonics tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
SOURCE: I need the code to att uverse cable box for Philips univ remote
I have the same exact problem, did you ever find the answer?
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
