NOTE: Print a Configuration Page before resetting NVRAM. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
To reset the printers NVRAM using the Control Panel:
SOURCE: how can you reset the waste toner counter?
Exactly the same problem over here ;-( When replacing the toner recently i forgot to switch of the power, so no reset. I can't find the reset option in the menu, resetting aal settings did not solve my problem.
SOURCE: How to reset Phaser 6110 imaging unit.
No reset for imaging unit, only when you change it(autoreset).
You can reset Fuser and Transfer Roller this way:
To reset the fuser and transfer roller life usage from the printers control panel:
a. From the main menu select, Menu-Setup --> Maintenance --> Check other.
b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons
c. Select Reset.
SOURCE: Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
