Question about Miele 24 in. G865 Built-in Dishwasher
My G865 Miele dishwasher goes partway through the cycle then gets hung up and runs without advancing. We left it running when we left for vacation and it was still running when we came back. I'm assuming it is the timer mechanism. The dishwasher is ten years old but has been run only every other day or so. Is it worth fixing or is it better to replace?
  • nvvroegop Jun 28, 2009
    So you are pretty sure it is the thermostat and not the timer mechanism? We have the same problem regardless of which cycle we try it on.
    Is this something we could do ourselves or should we hire someone to do it?
    Do you believe it is worth doing this repair for a dishwasher of this age (10 years but run only every 2 days or so).
  • nvvroegop Jun 29, 2009
    Actually, I was disappointed. I asked for elaboration on the first response from the first expert because he indicated a totally different problem from what the authorized Miele dealer guessed it might be based on an earlier phone consult. Unfortunately, the first "expert" did not deign to respond. Someone else with the not too promising monicker of "outofworkjoe" responded only with a statement that it would cost "a lot" to get it repaired and, since the appliance was ten years old I should replace it. Still not very helpful. No one seems to be capable of reading an entire email and responding to it. I'm just giving up on your service and writing the $10 off to my further "education."
    Sergeant:
    Champion:
  • 216 Answers
It will cost alot to get repaired,10 years old you got money out of this one.
Posted on Jun 28, 2009
    Brigadier General:
  • 3,917 Answers
Please replace the thermostat. Its underenath, behind the kick panals.....with the power off, it is fairly easy to change .
Thanks for contacting Fixya
G865 keeps draining during ever cycle
The selenoid that opens/closes drain function id burned out. Your local appliance parts store can provide a replacement selenoid and tell you exactly how to replace it.
Jan 05, 2012 | Miele 24 in. G646SC Plus Free-Standing...
Miel dishwasher G865 Was not cleaning dishes properly so I put some Power 1 which is similer to CLR, started a wash cycle then partly into it I switch it to rinse. Now it still the same and the water...
Sorry to read about your problem, I hope this helps you out.
you may have a clogged pump, or a defective pump.
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Miele 24 in. G865 Built-in Dishwasher
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
Dishwasher during normal cycle gets hung up and does not advance
HI. this is just a control fault. you can try to reset the core program by unplugging this unit for 5 minutes. this will drain all power and reset the core on the timer/control.
If you experience the same situation after this reset, simply replace the control/timer module.
Jun 02, 2009 | Kenmore Dishwashers
Dishwasher not washing
Check the very bottom tray under the machine. Remove the lower front cover, 2 screws, and you'll find a tray full of water.  A Turkey Baster will **** most of it out,  towel the rest.
Once dry, the machine will operate through all cycles, most likely.
This is a common problem with this model.  I have to do this about once a year.
Nov 18, 2008 | Miele 24 in. G865 Built-in Dishwasher
G865 - Constantly draining
Your problem is a water leak.  There are a couple of rubber seals that are required to correct the problem.. When the seal leaks it accumulates in a tray in the bottom where a sensor turns on the pump when water is present.  If you remove the lower access panel and reach in you should see the accumulated water.  I had a repair tech repair mine.
Aug 20, 2008 | Miele 24 in. G865 Built-in Dishwasher
Miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Jan 05, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G865 Built-in Dishwasher Logo
167 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
