My window unit. isnt as cold as years past think it needs freeon but dont know where to put it in at on my unit
    Scholar:
  • 70 Answers
Outside coil maybe be full of dirt. Fan blows through coil and dirt builds on the coil face that you can't see. Washing with a hose poing the nozzle at a 30 degree downward angle may help was it out. Some times it has to be taken apart to wash it out. If the air coming off the back side is uneven and very hot from top to bottom then it is most likely plugged up. Try not to spray water directly into fan motor. Low freon will normally make system freeze up after a while. Also abnormally high humidity and temps will make system seem not to cool as well.
Posted on Jun 28, 2009
I have a Goodman GPH1324H21A the fan comes on and the AC kicks on for a couple of minutes then shuts down what's wrong with it?
if it's 4 years old it doesn't have r22. Are BOTH fans running when ac shuts down? Inside unit or outside unit shuts down?
Jan 08, 2018 | Goodman GPH1324H21A WallWindow Air...
Kia air conditioner doesnt work
I have a 2007 kia rondo.Ac was working,parked it for a year,ac wasnt working,recharged,the ac,it worked for a month,an started again,blowing hot ai.If you let it set for hour would start working...then after a few days it would only work early morning,if you dont turn ac of,then it stop working,I see the clutch isnt kicking in,ir you try an put freeon in it soon as you start putting it in it would kick on.An its full of freeon.
Mar 11, 2012 | 2007 Kia Rondo LX V6
I took my 2000 honda civic ex to see why the air conditioning is blowing warm or hot depending on outside temp. He put it on the diagnostic machine and told me what was wrong is something behind the...
he was refering to the condensor just have it checked to see if there is to much freon or not enough this will cause freeze over they are in buisness to make money and are not always truthful about the problem if it is not the freeon level then its more than likly the condensor
Jul 08, 2011 | Honda XR230 Motorcycles
Needs freeon fix self or take somewhere
Adding refrigerant is not a do it yourself job. Most likely, you just have a plugged air filter. Generally, you will find a washable nylon mess filter just behind the front grill.
Jul 09, 2010 | Goldstar KG6000R Window Air Conditioner
My unit is 3 years old. We have recently heard
sounds like the evap coil is freezing. it is frozen if you have low air flow. check the lines and see if your suction line is freezing. also check your filter. if you think your drain line is clogged cut the line and blow out with an air compressor or nitrogen. all you should need to fix the line would be a 3/4 in coupling or a union. hope this helps
May 31, 2010 | Goodman CLQ60AR61 Air Conditioner
Ac works but not cooling. The thermostat dosen't work properly.
open unit an check the thermoprotector on the compressor thats the problem
May 16, 2010 | Friedrich CP12C10 Wall/Window Air...
Freeon is good dont know what else it could be. when its cold out the ac works fine but when its hot it doesn't blow cold? WTF
The ac will blow sold when its cold outside.It is just the air from the outside. You need to check to see if the ac clutch is turning when the ac is switch own.You may have a bad ac compressor
Mar 05, 2010 | 2002 Mitsubishi Lancer
Where do i put freon in to fill it up 12000btu AC needs freeon i need to know where the fitting is to fill it
No access ports on window units. Need a line tap for that or call service tech. There is oly so much you can do without knowledge of air conditioning. russ
Jul 31, 2009 | Heating & Cooling
A/c compressor kicks on, but no cold air..checked all the fuses and relays. Everything seems fine. Any one knows what could cause this?
well if you dont have freeon it wont be cold and also you may need your condensor checked had an 03 jeep grand cherokee laredo that the condensor went bad and had same symptoms.
Jul 31, 2009 | 1999 Buick Regal
FORD FOCUS ZTS 2004
at the top of the engine under the window under something else about right in the middle you'll see a green cap. you put it in there. i know cause it took me 3 days to figure it out.
Jun 09, 2008 | 2004 Ford Focus
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
