Question about McCulloch Garden
What is the gas mixture for saws - McCulloch Garden
50to1
Posted on Jun 28, 2009
Saw starts and loses power and dies when i pull throttle
It sounds like it is running too lean on the mixture, if it is new take it back to have the mixture richened up, if you carry on running with a lean mixture it could seize.
May 03, 2012 | Craftsman 38cc 16 In. Gas Chain Saw
Does this take straight gas?
Your saw most likely requires a gas/oil mixture. a 1:50 mixture (1 part oil to 50 parts gasoline) is common among newer saws. Some older saws (20 years or more) require a richer mixture, commonly 1:40. I recommend you consult the users manual for the saw.
Hope this helps.
Apr 26, 2011 | Garden
How do you fix as carborator for saw that has gas mixed to rich one of my employees thought it would be good to mix it 8 ounces to a gallon
First pour out all of the old mixture. Put in the right mixture. Pour an ounce or two of raw gas down the throat of the carb or inject it wit an eye dropper.(what ever works the best. The raw gasoline will run for a few seconds but will not hurt the engine. Let saw run for a while until the blue/white smoke clears. Running a saw on too much oil mixture is much better than running it on too lean as that is the way the piston is lubricated. The problem with too much oil is that the oil is sticky and clogs the exhaust ports of the 2 cycle engine, but running it on the correct mixture should correct that.
Jan 06, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Chain saw starts and will run a full tank of gas. After refilling the gas tank.the saw will not start until it cools down.
Check your fuel mixture, check the air and gas mixture, you should be able to find how they need to be set for your machine on the internet, or call the manufacturer
Jun 14, 2010 | Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
