Hi Friend, this is Z. Thank you for your post!
I understand your Frigidaire freezer is leaking and not defrosting; however is water leaking from behind, front or underneath? Also, did you notice any error codes, noises, or other strange functions prior to this issue? With this information I can assist you better in pinpointing the problem.
SOURCE: LEAKS WATER WHERE WATER LINE GOES INTO FREEZER.
An easier fix is to redo the connection. Turn off the tap the supplies water to refrigerator, should be on your cold water line under the sink. Remove not on the solenoid valve(blue valve) slide the nut further up the vinyl tubing cut the tubing above the old connection. push the tubing into valve and tighten nut finger tight. turn the tap on a little and check for leaks at the solenoid. If no leaks open tap all the way. If leak tighten nut a little more only until leak stops. then turn tap on all the way.
SOURCE: Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
SOURCE: water pools at bottom fridgidaire freezer
sounds like your drain is plugged up....call for help on solving problem...
SOURCE: water leaking inside refrigarator from ceiling also some ice in f
good day,
hope this link below will solve your problem.
ref
