Question about Tamron 28-200mm F3.8-5.6 for EOS
Its says error 99? means? can somebody help me? saying shooting not posiblle , needs to turn off/ then turn on.. and i tried so many times but it never helps. please help me .
  • 390 Answers
Hi
this error 99 is generally occured when the lense is not recognized
this has been a common problem reported
we'll clear the contacts and connect the lense
try turning the Image Stabilization off and this could solve your problem temporarily
hope this helps
cheers
pls reate the solution if this helped any
Posted on Jun 28, 2009
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Error 98 is my problem and nobody can tell me how to fix it?
Error 98 & 99 means a NONSPECIFIC error message.
It may be a lens problem. It may be a shutter problem. It may be a battery problem. It's Canon's way of saying "Something happened, and we don't know exactly what, but we know it isn't right". You're going to have to try to narrow it down by using fresh batteries, trying different lenses, trying different shooting modes, shooting wide open in AV, manually focussing, turning off IS if you have it.
In short, if it happens regularly, try to identify what you're doing when it happens and how that differs from when it doesn't. But don't expect somebody else's solution to work for you. Their camera may have a different problem.
Are you try contacting the Canon Support?
May 23, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Error 99 when I turn my canon reble xsi on The screen says "Err 99 Shooting is not possible. Turn the power switch to off and on again or re-install the battery" I have done all of the above...
Welcome to Fixya
Thank you for choosing Fixya!
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
I have cannon EOS 400D problem is error 99, some times after shooting
Welcome to Fixya
Have a good one!
Apr 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
HOW TO SOVLVE PROBLEM COM SEVER TIME. ERROR 99
Welcome to Fixya
Thank you
Apr 06, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Camera turns on and works but has constant error cf and when you try to format the card reads error 99
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Feb 13, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Cannon 400 error message 99
Error 99 is a NONSPECIFIC error message. It may be a lens problem. It may be a shutter problem. It may be a battery problem. It's Canon's way of saying "Something happened, and we don't know exactly what, but we know it isn't right".
You're going to have to try to narrow it down by using fresh batteries, trying different lenses, trying different shooting modes, shooting wide open in Av, manually focussing, turning off IS if you have it. In short, if it happens regularly, try to identify what you're doing when it happens and how that differs from when it doesn't.
Apr 10, 2010 | Canon Cameras
Tamron 28-200mm F3.8-5.6 for EOS Logo
202 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
