Question about GE AJCQ08ACB Air Conditioner
I have a GE air conditioner with ditigal panel. I
I have a GE air conditioner with ditigal panel. I set the temp to to 64 degrees and then the room temp displays. And the room temp never gets below 72 degrees. Its a 10,500 btu for 417 sq ft. Is there something wrong with the unit?
  • jcorrea421 Jun 28, 2009
    The unit is brand new. Not even a week. Even when I'm alone in the living room it never goes below 72 degrees. I only turn it on during the day.
    Scholar:
  • 70 Answers
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Posted on Jun 28, 2009
  • Kendall Clendenen
    Kendall Clendenen Jun 28, 2009
    Where do you live. If it is really hot out that might not be to bad. Not leaving it on to keep humidity down can also effect the cooling. If you have a lot of sun exposure and not much insulation and leaky windows this too will affect it. let it run after sun down and see if it comes down more. Also check and make sure that it hasn't got a low limit override built in. You may be able to change that by reading your owners manual. With the info I have to go on I would say it is doing all it can.I would let it run all night and see what it doe's. You may need to set it up some as it may get too cool.
My thermostate will not shut off when the room temperature drops to 72 degrees in which my thermostat was set at on the auto cool setting. It even continues to run and drop below 72 to 68 degrees and never...
What brand and installed in what? If a thermostat is installed on a wall that is heated by the sun it will give false temps. If it's mounted too low or high it will not be right either.
Oct 08, 2014 | Heating & Cooling
Just installed a GE ajcq12accm1 and it will only cool for about 5 minutes, then blows room temp air ........do you have any tips on fixing this...please ?
Besides calling out a certified ac tech. It may be the t stat set at a higher temp than actually is in room. (Calibration)
May 28, 2012 | GE Built-In Room Air Heat Cool Air...
It is 94 degrees out side and inside air 78 i got the troastat set on 72 what does it meen that it want get 72 in the house
depending on the current conditions inside it appears to be wotking fine with the heat load. what I am saying is -is that the air coming out of the unit shuld be about 15-20 degree lower than the temp of the room .. close all unused room s and it will do its job.. Hope this helps let me know Jon
Jul 27, 2011 | Haier Energy Star ESA3183 Air Conditioner
The temp setting shows 78 degrees,lower to 72 degrees /it stays for 15 sec and returns to 78 degrees no codes
you may not be giving the a/c enough time to cool down to 72 the reason it goes back to 78 is that is the temp in the room at that moment put on 72 and give it about 20-30 min. to see if this helps
Jul 03, 2011 | Sharp AF-S120FX Air Conditioner
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP...
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
Jan 08, 2011 | Heating & Cooling
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations?...
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Jul 15, 2010 | Amcor PLM-14000E Portable Air Conditioner
When I cool the room it doesn't drop to the temperature I have it set to but a few degrees celcius higher. Is that normal? I honestly never checked on my old unit but this one doesn't seem to feel as cool.
there is suppose to be 15--20* temp. different on the air supply & return air temp.Over 20* and the coil or the filter is plugged up. Below 13*--anf the unit is not charged properly.
Dec 02, 2009 | GE Quiet-Aire Ductless Split System Air...
My Whirlpool window a/c is not cooling as well as it did last sum
I know it has been at least a year since your post. I am answering the post to terminate FixYa site activity on the post.
Remove the front cover. Check the routing of the temp sensor wire. It should go from the bottom of the control panel to the plastic clip in the evaporator coils. If it is touching the eavporator coils it will sense the refrigerant temp and cycle off early. If the unit is freezing up there is a restriction in the coolant lines and usually will require the coolant system be purged of foreign internal debris.
Thanks for choosing FixYa.
Kelly
Jun 25, 2009 | Whirlpool ACC108PS Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
429 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
