Question about Delphi SA10034 Shelf System
No sound from the delphi system. No sound from the cd or the radio. I cant figure this one out.
Code for stereo famar delphi model df 741 please
I need code for Famar Delphi serial number 0851482 part number A690820087
Thank's
Apr 08, 2010 | OEM Systems Car Audio & Video
I lost my code for my vectra CD radio
I have a Vauxhall Astra and i have lost the code for its can anyone help me please. Below are the details on the radio
Delphi Grundig
GM497316088
No. 13289921
Thank You
Feb 24, 2010 | Blaupunkt Car Audio & Video
My delphi roady plays through cassette adaptor. Volume is very low even when audio level is moved all the way up. ???
You need to cycle back through after puttung the cassette in. Mine did that (before the cassette feature stopped working altogether) and I would press my "source" button so it would go from the cassette to the radio, then CD and back to the cassette - the sound would be back to normal again.
Oct 06, 2009 | Delphi Roady XT XM Radio Receiver
Connection
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Feb 02, 2009 | Delphi Roady XT XM Radio Receiver
HAVING TO USE ANTENNA AIM FOR 2 HOURS TO GET SIGNAL.
FIXED! smashed it on the floor. best move i ever made.
DO NOT BUY A DELPHI. DO NOT BUY A DELPHI.DO NOT BUY A DELPHI.
read reviews before buying any sat radio, good luck.
Jan 21, 2009 | Delphi Roady XT XM Radio Receiver
Cd stuck in stereo
Delcos are notorius for this kind of thing. Since you have 2 radios, you will have one to practice on. What you really need to do is remove the radio from the dash, remove the appropriate casing from the delco radio and push the cd out manually. I typically use dental picks to fit into tight spaces. Once you have the CD out of one of them, you can either have someone swap them for you, or since you are experienced in the process do it yourself.
Jan 20, 2009 | Delphi Car Audio & Video
Lost the user manual
go to google.com and type skyfi2 xm radio manual. you will find the manual there as a .pdf file.
Dec 23, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
How to use Delphi SA10000 with out a tape adapter?
you need to be a fm modulator for that unit. that way you can just tune it to 88.1 no wires well the least wires
Oct 21, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Delphi SA10034 Shelf System Logo
76 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
