Question about Garden
Snapper weed trimmer keeps stalling
I cleaned the entire engine and it starts with one pull. But it stalls and will not let me put the choke in the run mode. It acts like its not getting enough fuel. What and how should I adjust?
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Engine dies when engaging blades
pull the carby and clean out the bowl and main jet
check for a blockage in the fuel lines to the carby, including the fine mesh filter in the tank at the tap
Jul 29, 2016 | Kohler Command OHV Horizontal Engine with...
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
My Ryobi ry3002a weed trimmer won't idle. It shuts off as-soon-as I move the lever to run position. I disassemble and clean the carburetor but no luck. Any suggestion?
Run at 1/2 choke rev the engine & count to 10 showly. The engine should now be warm enough. If it still stalls, turn up the low idle screw.
Aug 24, 2015 | Ryobi Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Poulan pro ppb350 weed trimmer stalls when choke is open
    -After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
    Because the engine need more air to burn the gas.
    Good Luck
    mai
    Jun 06, 2014 | Garden
    Sym red devil feels sluggish
    Instructions
      • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
      • 2 Pull the kill switch up.
      • 3 Turn the key to the "on" position.
      • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
      • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
      • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
      • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
      • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
      • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
      • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
    Jan 15, 2013 | 2008 Sym Jet Red Devil 50
    Husqvarna weed eater starts , but blows alot of smoke & then stalls out
    Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    String Trimmer Starts Then Stalls
    My String Trimmer Starts But Won Stay Running
    Craftsman Trimmer starts then dies
    How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
    How to Clean Two Cycle Two Stroke Engine Carburetor
    Sep 06, 2012 | Husqvarna 128 LD Weedeater
    Garden Logo
    132 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
