Question about Technics SL-MC700 110-Disc CD Changer
Front door won't open
Disc won't play, front door only opens half way, and there is a clicking sound as if the player wants to change discs but can't do it. Can't turn machine off.
  • atisun7 Dec 10, 2007
    there were cd's stuck in one slot, one cd was on the floor of the player, took all the cd's out. the wire that goes from one side to the other has come off from the left side. does not turn off. nothing works
  • 983 Answers
Open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
bye cleaning lens it will solve ur playing problems slightly..
and by cleaning near by & bottom of door and door way solves ur half way ejection problem
Posted on Feb 06, 2008
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc door frequently will not open and now it
One of the things you try for this , is to remove moisture that has collected in the machine, this could be due to it being in a cold room,or not used for sometime.
bring it into a warmer environment switch it on and leave for 2 hrs then retry your discs.
Also check the region on the dvd matches that on the discs.
Please see your manual for discs your dvd won`t play,also about finalising.
Oct 20, 2009 | Televison & Video
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off. can be fixed with a small elastic goody hair tie w/o metal clasp
Feb 11, 2007 | kawasaki SVP500 Multi-disc DVD Player
Technics SL-MC700 110-Disc CD Changer Logo
258 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
