Question about NetGear ProSafe GSM7248 48-Port Gigabit Ethernet Switch
Problem faced with the NETGEAR GSM7248
The problem in the netgear GSM7248 are
1. The system host would not intialize or connect via putty
2. communication failed when ports 25,26,27, and 28 were used.
  • 3 Answers
SOURCE: Trying to connect two PC's
Any network device, PC or otherwise, needs an IP address assigned. So, yes, both your PC's need an IP address.
Assuming your ISP lets you have multiple PC's(IP's) then you'll have to use the IP space provided by your ISP. The default gateway would also be provided by your ISP.
The way you SHOULD do this is to use a router, linksys for example. This way you can setup you private network(I.E. for example). This will hide and protect YOUR private space from would be hackers. The router would use the REAL IP address on the outbound side to talk to the cable/DSL modem. can use the ipconfig command at the command prompt(I.E. a DOS window) on your working machine to see the DHCP address and gateway that was assigned. Sound like your ISP only allows you one IP. The router solution above will fix that and let you connect as many as you want because the ISP will only see the one IP from the router.
Posted on Jan 08, 2009
  • 12 Answers
SOURCE: Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Posted on Feb 18, 2009
SOURCE: Problem replacing 4 port hub with 8 port switch for home network.
You can obtain IP details for Preferred DNS server & Alternate DNS server from your internet service provider.
don't use automatic ip addresses.
best regards,
Posted on May 08, 2009
  • 1272 Answers
SOURCE: i have connected the netgear GSM 7324 switch to my
Hi, The best support you will get for this product is by logging to NETGEAR support site
Posted on Jul 28, 2009
  • 854 Answers
SOURCE: DHCP problem and router connection
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing or in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
  • 1272 Answers
SOURCE: I have a Netgear GS605 5 port switch that
Wel the issue is clear. Your printer supports maximum connectivity at 100mbps and hence it is getting that much bandwith from the switch.
Posted on Aug 25, 2009
0 characters
1 Points
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
Default password
The default password is blank (i.e., leave the password field blank).
Nov 18, 2013 | NetGear ProSafe GSM7248 48-Port Gigabit...
Unable to detect my Netgear Gigabit smart switch GS748T via Smartwizard discovery. Earlier have tried reset the switch to factory default but to no avail. Pls help.
First, make sure your switch and PC are in the same broadcast domain/subnet, and that there is a DHCP server in operation.
Second, make sure you are following the "factory reset" procedure correctly (
Third, check your version of Smartwizard Discovery, and download a newer version if one is available. I think the latest version is 2.05.05 (download from
Sep 28, 2011 | NetGear ProSafe GS748T 48-Port Gigabit...
All lights on all connected ports on a netgear gs105 switch rapidly flashing constantly; data traffic seems slow or drops. Occurs regardless of how many devices connected or which ones.
1. A switch is a dumb device it just transfers data via the ports
2. if you are having slow or dropped data this possibly is due to bandwidth issue.
3. contact your internet service provider to check your speed and you line condition.
4. You didn't say if you were using a router, but if so this could what is call "collision"
5. some switch do this due to speed of the data throughput\.
Jun 23, 2011 | NETGEAR ProSafe GS105 - Switch - 5 ports -...
I can't connect to internet via my tv all the sudden . I streamed a movie on netflix just fine just yesterday . Today it won't connect . I checked allt he wires and connections to the computer and modem...
Here are a few things to try:
- Remove all the devices plugged into the netgear and leave only the TV and Internet connection
- Swap the cable for the TV Internet connection
- Try a different port on the netgear
- Monitor the activity lights on the netgear
Are you still able to connect to netfix via a computer?
Post any findings
Apr 26, 2011 | NetGear ProSafe 5-Port Gigabit Desktop...
Need to replace fans on netgear GSM7248 that is out of warranty. Where can I purchase them
I bought them from Digi-Key. Just google the part number on the fan for specs and match that up with the parts at digi-key. My GSM7248 has new fans, new low voltage caps, new heatsink retention clips and a new power supply. They should be selling these POS switches for $250.
Aug 12, 2010 | NetGear ProSafe GSM7248 48-Port Gigabit...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
I have an Apple Mac connected to Netgear router. Partner has Del laptop which she wants connected via my router. Bought D Link 1005D switch but don't know how to connect both of us thru it. Do I need set...
What type of Netgear Router you are using?
If you have more than one ethernet ports to your Netgear Router, then connect your switch with a patch cable to the Router. Switch on it and check.
So that can share the resourses.
Dec 28, 2009 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
NetGear ProSafe GSM7248 48-Port Gigabit Ethernet Switch Logo
Top NetGear Networking Hubs & Switches Experts
Are you a NetGear Networking Hub and Switch Expert? Answer questions, earn points and help others
