Question about Epson Office Equipment & Supplies
Only when I print photos I get grainey lines I went through the cleaning process several times even called epson to troubleshoot no luck
  • Epson Master
  • 511 Answers
Check nozzle? All lines appear? vertical line for each ink is straight? Another ink droped outside lines?
Posted on Jun 29, 2009
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
The Black is not printing, even after cleaning the head several times
With the EPSON'S you must "Genuine" Epson Cartridges. It does not print good with Generic.
I went thru 2 sets of cartridges, trying to clean the heads alot of times. Finally, had to buy another one.
If you are using generic, change back and see what happens and try again. If not , Good Luck.
:0(
Nov 18, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson stylus photo 890 printer (5 years old)has
Do a cleaning several times. If that doesn't do it, then it is time to get a new printer. They are cheap enough and will be cheaper than bringing it to the repair shop.
Apr 22, 2009 | Epson Stylus CX9400 Photo Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson C84 inkjet
This typically is not an issue with re-fill cartridges, but it could be. At this point, if you have replaced the cartridges, ran cleaning cycles AND called Epson, that's all you can do. I would advise just replacing the unit as it's too expensive to fix.
Sep 12, 2007 | Epson Stylus C84 InkJet Printer
C66 Inkjet Printer
If you have tried new cartridges and many cleaning cycles with no change, then it would be best to just replace the unit. Contact Epson as they may be able to offer you a good price on a replacement unit.
Apr 02, 2007 | Epson Stylus C66 InkJet Photo Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
