Question about Ricoh Aficio 1013F Copier
Close ADF cover 4732 on a Ricoh IS330DC. How do I fix this.
    Scholar:
  • 175 Answers
I'm not familiar with this model, but if it says to close df cover, then either the cover is not closing all the way, a plastic piece on the inside of the cover that actuates the switch or sensor is broken or the switch itself is out of position, dirty or broken. Good luck Colin
Posted on Jun 29, 2009
REMOVE PAPER FROM ADF
1 - Open the ADF cover
2 - While pushing the release button, lift the ADF unit
3 - Remove the jammed paper
Aug 07, 2014 | Ricoh Aficio Office Equipment & Supplies
Paper jaming in ricoh af 1022 in adf
Paper jams in Ricoh Adfs ( or others), generally have origin in dirty rubber rollers. Oh yes, they can look clean but try to wash them with Benzine and check the cloth! You have to have full traction between the rubber and the paper , otherwise they skew and jam or are not picked up even. Other problem is in the exit (lower ADF side) , a misalignement between adf and the machine body. This can be solved with the mounting screws in the Adf back. Dont forget to have the paper format sensors (top right of ADF) clean and last, you may want to check the horse shoe sensors INSIDE (rear cover ADF). In my lifetime as a Ricoh tech, it only happens this once, and because the machine suffered ADF damage due to Portuguese bumpy roads, Ahahah. I am excluding the obvious, such a paper clip, a stapple, a coin , etc.. This happens very often...
Feb 22, 2014 | Office Equipment & Supplies
The fax/ printer says close adf cover then press stop, the cover is closed down properly and there is no paper jams everything is closed properly ?? what do i do to fix it? thanks!!
the ADF cover is the automatic document feed. make sure the cover above that tray is closed tightly. maybe try opening it and reclosing it. sometime the sensors get jammed up.
Nov 08, 2012 | Office Equipment & Supplies
C6 ERROR
C6: Cover open ,Close the ADF cover ( located in the upper cover right side )
Jan 26, 2011 | Ricoh FT5832 Copier
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
Remove paper from adf error ricoh aficio 2020
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
Jul 31, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Apr 22, 2009 | Ricoh Office Equipment & Supplies
Stacking
If you have an ADF, please put the 35 originals in the ADF and just press the Start button.
You will have 35 copies in the output tray.
If you don't have an ADF, please put one original on the platen glass, close the platen cover and press the start button.
Then replace the original by the 2nd one and continue the rest of the procedure and do also for the remaining originals.
Good luck and please rate me, thanks.
Oct 31, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
311 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
