Lexmark X1150 All-In-One InkJet Printer Logo
Posted on Nov 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I find the switch that closes the cover?
My computer keeps telling me that the cover is open and would like to know where the sensor is located on my Lexmark X1150 all in one printer .
Thomas Christopher
Level 3:
Genius:
  • Master 1,601 Answers
  • Posted on Nov 16, 2007
Thomas Christopher
Master
Level 3:
Genius:
Answers
1601
Questions
Helped
1052565
Points
3958
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Try to determine if there is a hardware fault. Do the following:
    1. Disconnect the power cable and the USB cable.
    2. Remove the cartridges from the printer.
    3. Check that the power cable is plugged directly into a wall socket.
    4. Reconnect the power cable.
    5. If the error persists, please contact Lexmark for further instructions.
2answers
Close door message
The unit should run when out of the cabinet on its track glides. However the small cover lid (door) on top of the machine where you would put Ground Coffee in has a switch sensor on it. The cover acts as a magnetic switch and it must be in the closed position. My display says "close the lid" if left open. Since Thermador tells you to call a repairman for everything (which is hard to find one that can work on it) I've had to take every cover off for dis-assembly and repair. With all covers off the machine the only thing I had to do was to "Jump" the ground coffee wire connecter to make it run with no covers on. It makes great coffee but tough to get repaired. Let me know if that was it.
My printer keeps saying " cover open" but it
Possibly because upon closing it the cover didn't press down the switch for some reason, just look around inside it, and check if there's any piece of paper covering the sensor or the sensor switch might be visible and broken.
Cover open sensor is knocked off the switch assembly - Please show and tell me how I can repair it.
Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset it. When the printer turns on, reinsert the cartridges. Make sure the cartridges are properly inserted in the carrier and the lids snap in.
Source: Error: 'Cover open, please close the cover'
8helpful
2answers
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
1helpful
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
2answers
Top cover does not seem to close, and keeps stating that its open, when it is closed.
Your printers top cover is closed. Its generating error just because of faulty sensor. You require to change the sensor. If you are assured that you can do it yourself with our guidence then kindly comment back, or else simply take it to a technician.
3answers
Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
1helpful
I have a Brother MFC-7220 USB printer. It keeps telling me that the back cover is open ... and it is closed. Now I cannot use it. lease help. Thanks.
hte back cover has a little micro switch.
open the back cover, make sure there is nothing preventing from closing tight. close the back cover tight. if you have to, use tape to secure it.
Cover open sign shows all the time
There is an interlock switch or sensor on all the covers. You need to open the cover and look for an opening in the cover it closes against. In those openings there are normally switches that a tab turns on to let the machine know the cover is closed.
The switch may have become dislodged, or more likely, the tab on the cover that hits the switch to actuate it has broken off and is not hitting the switch giving you that message.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
