Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Looking for belt diagram for 46" mower deck fro my JD LT166
And can you put it on without taking off cowling on far outside pulleys
  • 3 Answers
Diagram: looking for belt diagram for 46
Posted on Aug 12, 2009
Have a JD LT166W/48 and need a mower deck belt
Do you mean the John Deere LT166 Lawn Tractor with 48" Convertible Deck mower. If so, the replacement belt is GX10063, according to the maintenance sheet: https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LT166_48CdeckLawnTractor.pdf . One vendor has the belt here: http://www.greenpartstore.com/John-Deere-Drive-Belt-GX10063.html .
I hope this helps. If you have a different mower deck, please add a comment with more information about your specific mower. I may be able to find additional JD parts for the machine. You can also look up parts here: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt .
May 31, 2017 | Garden
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
I need a belt diagram on a sentinel 12 hp riding mower
Are you still looking for that belt diagram..? Is this for the motor to trans (which is pretty simple) or the belt to the deck..? Couldn't find a diagram so hope my drawing comes out right.. This is for the deck belt routing..!!!
Left pulley (O\ /O) Right pulley
. Tension \ \@/ / Pulley
. Engine \ @ / Pulley
Front of mower here. Main thing is, you take the belt from BETWEEN the right & left pulleys, pull it down and around the tension pulley..
Apr 09, 2013 | Garden
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Apr 28, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
I need a belt diagram for a lt166 john deere mower 48''deck
From the JD site, you can get the drive and deck belt diagrams here:
***Don't forget to VOTE for the guys who take an interest in helping!
May 25, 2010 | John Deere Garden
John Deere tractor
Ok Simple Rule
V BELTS go in V pulleys
Flat pulleys get the back of the belt. You must take the deck off the tractor to do this properly. Look inside the hood I have seen belt diagrams there or on top of the deck.
When all else fails Go to the JD Dealer they will gladly help.
Sep 29, 2009 | Garden
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Apr 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
John deere 316 belt
I am so far from expert...me answering this surprises me. However, I can...JD Small Engines has plenty of diagrams for the 316. Here's how a old single lady changes the belt on her 85 316. There is a bolt running from side to side of a black metal box...on the very front at the bottom of the mower below the grill. If you pull that out, just the front of the mower deck separates from the mower..slip the belt in and around the rear central pulley. Put the pin back in with the belt now around the back pulley and outside the part where the pin goes back in. Get a pneumatic tire jack and jack up the right (your left as you face the front of the machine) front pulley..try to catch the pulley armature or bolt so you don't torque the pulley. This releases the tensioner...thread the belt on the right pulley and reach up under the grill and put the belt over the front engine pulley....now all that's left is to get the belt over the left pulley. At this point, I remember having to either lower the deck to the ground or raise it up all the way...to the ground, I think as it wasn't already in the correct position. Once you start fussing with the left pulley, you will see it is spring loaded and easy to force the belt over if the right pulley is still on the jack. Really important to get the belt inside all the belt guides and lowering the deck before you frustrate yourself with getting the belt over the last pulley. When all is done, release the jack and everything tightens right up.
Mar 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,724 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
