Question about Ariston Technologies Washing Machines
Washing machine stops working with delay timer flashing
Washing machine starts alright but stops working after 5 mins, and delay timer light & easy iron light switches on and off together
  • 4 more comments
  • mmbtestro Jun 28, 2009
    i have reset the washing machine to a different cycle but still the lights keep flashing,
    i have tried to reset the washing machine but it is still stopping and the delay & easy iron light is on
    the mod AVL 85S EU 220-230V - 50 HZ type LB2000c
    model AVL85S EU
    i have sent the model number of the washing machine, but had no replay.
    mandy testro
  • mmbtestro Jun 29, 2009
    i have notice that it is filling in the prewash compartment although it is not set for that cycle,
    i did use the prewash cycle before this problem began
    Sniper:
  • 111 Answers
This could be a worn out or loose belt.
You can get to it through an access panel on the back of the machine.
Just make sure the power is disconnected first!
Hopefully a replacement belt will be easy to obtain in your area.
Regards
Posted on Jun 29, 2009
  • 2,200 Answers
Before we go any further can you clarify the exact model of this Ariston washing machine please.
I will troubleshoot your problem from there but need this information first.
Thank You.
Posted on Jun 28, 2009
  • 1 more comment
  • Radio Code Pro
    Radio Code Pro Jun 29, 2009
    Ok please bear with me. I am looking at your issue right now.
  • Radio Code Pro
    Ok - what is happening here is that your washing machine is tripping a fault code when it enters this part of the cycle 5 minutes into the wash. It is then communicating the fault code via the flashing lights on the panel.
    Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights
    This is a very basic system of fault reporting as more advanced machines will display a numerical error code on the panel which can immediately be linked to the cause of the problem.
    Many people blame the program timer for this problem but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, or if it can't empty the water.
    However, the most common causes of a washing machine sticking mid cycle are water filling and water emptying problems.
  • Radio Code Pro
    Can you tell me
    1) Is the machine filling properly with water at the start of the wash?
    2) Is the machine full of water or empty of water when it stops mid cycle.
    My main suspiscion is that the machine may not be draining the water properly during its mid cycle. This will cause the cycle to stop and the errors to flash on the control panel. The possible causes of this are blockages or pump failure.
    I can advise further once you have responded to these questions.
    Sergeant:
  • 326 Answers
Reset the washing machine
How do I get the delay wash light to stop flashing on my dishwasher
Unplug the washer from the wall for 1 min. then replug & give it a try. That should reset everything.
Sep 15, 2014 | KitchenAid Dishwashers
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
422 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
