Question about Ovens
Oven door will not stay closed, it stays open about 2 inches, is there a simple adjustment that can be done
  • 157 Answers
Replace hinges
Posted on Jun 30, 2009
Door stays open about 2 inches
Replacing the hinges is risky because you need to be 100% sure the new hinges go back in the exact spot the old ones were.
Otherwise, there might be leakage, which can lead to arcing and possible fire.
The exploded view / parts list is here.
If the hinges are not secure, the door may slip, which can cause leakage or failure to operate correctly.
Also, there is a bulletin about these regarding the door locking _closed_ but maybe it's applicable in this case, too.
Here's the text of the bulletin:
KitchenAid & Whirlpool Electric Wall Ovens And Dual Fuel Range
MODELS: KEBC101K, KEBC107K, KEBC141K, KEBC147K, KEBC171K, KEBC177K, KEBC206K, KEBC207K, KEBC208K, KEBC247K, KEBC276K, KEBC277K, KEBC278K, YKEBC107K, YKEBC177K, YKEBC208K, YKEBC278K GBD277PD, GBD307PD, YGBD307PD, GMC275PD, GMC305PD, RBD245PD, RBD275PD, RBD276PD, RBD305PD, RBD306PD, RBD307PD, AND KDRP407HS
PRODUCTS BUILT BETWEEN CODE DATES: XP22 - XP29
CONCERN: Error Code "F5 E1" or "F5 E7" (door latch not unlocking the door after self-clean cycle).
CAUSE: This problem is caused by defective material in the core of the solenoid on the door latch. The solenoid works properly at normal temperatures, and at the beginning of a self-clean cycle. However, when heated, the plastic core binds the metal plunger, and will not allow it to unlock at the end of a cycle. Once cooled, the solenoid will again work properly. When a technician inspects the solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Jul 23, 2013 | Ovens
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Oven door will not stay closed so temperature does not stay constant
either the seal,or spring device.
some doors come off,if you open partially and lift it,it might come off,and you can adjust it by repositioning it slightly?
Dec 18, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven door will not close completely stays open about 1/4 inch
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Sep 03, 2009 | Bosch Ovens
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Ovens Logo
481 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
