There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Was this helpful?
Yes
No
Popular Solutions for Admiral AW22 Top Load Washer
Our capacity plus Admiral washing machine has a problem with the mixing valve. How do we get to it?...
(More)
Our capacity plus Admiral washing machine has a problem with the mixing valve. How do we get to it? It was fixed once before. We don't know how to get into back of washer.
admiral super duty toop loader makes loud noise and will not spin, just started doing this, smells...
(More)
admiral super duty toop loader makes loud noise and will not spin, just started doing this, smells like something is stuck, belt burning, but there is not a belt to be seen
