1993 Jeep Grand Cherokee Logo
D
Dawn Helton Posted on Jul 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The check engine light is not coming on when i start my 1997 jeep grand cherokee ?
The Jeep starts and runs for a few minutes and then it starts running rough but it does not stall. Check engine light does not come on when you start it. How do I check the bulb?
Ron
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Jul 06, 2014
Ron
Expert
Level 2:
New Friend:
Answers
96
Questions
Helped
48725
Points
306
Sounds like a few issues. The check engine light should come on when you turn the key to "ON" without attempting to start it. If it doesn't, the bulb could be bad and that would mean removing the instrument cluster to change the bulb.
The rough idle issue could be a partially stuck open EGR valve. Remove the valve and clean it good. While you have it out make sure the diaphragm moves freely. Replace the valve if you can't clean it or if it doesn't move.
Go to your local auto parts store and ask them to read the codes (most store provide this as a free service).
5 Related Answers
Anonymous
  • 2920 Answers
  • Posted on Aug 22, 2008
SOURCE: 2001 Jeep Cherokee Sport - check engine
warped heads will cause this...if it over heated badly thats going to be the problem
Anonymous
  • Posted on Mar 24, 2009
SOURCE: rough idle stalls at low rpm's
check your transmission fluid,the motor will stall when fluid is low
Anonymous
  • 1071 Answers
  • Posted on Jul 23, 2009
SOURCE: 2003 Jeep Grand Cherokee check engine light stays
go to autozone they will check codes for free
Anonymous
  • 6982 Answers
  • Posted on Jan 13, 2010
SOURCE: 96 Jeep grand cherokee. 4.0 Running rough and
fuel pressure seems a bit high...could be a bad regulator. can't remember if yours is on top of the sending unit (on tank) or on the fuel rail though. Do more testing there.
Anonymous
  • 3640 Answers
  • Posted on Jan 21, 2010
SOURCE: 2002 jeep grand cherokee with 4.0 engine will die but restart
p0340 is the cam shaft sensor, this will cause it to cut off while driving, hardtime starting, p0351 is the ignition coil A primary/secondary curcuit mal function. p1391 is ignition system misfire, this could be plugs, wires, or coils. first of all have the cam sensor changed and it may correct the rest of the codes. when fixed turn light off with obd2 scanner. if you do not have one, then any auto parts store will erase the codes fo free of charge.
2answers
1997 Jeep Grand Cherokee starts but shuts down after a few seconds.
https://www.google.com/search?rlz=1C1CHBF_enUS757US757&sxsrf=ALeKk01pb5OD-dO7NbzwvZN4ZADFalsVlw%3A1615749844954&ei=1GJOYI_fOY6m_Qacp4GYAQ&q=1997+Jeep+Grand+Cherokee+starts+and+dies&oq=1997+Jeep+Grand+Cherokee+starts+and+dies&gs_lcp=Cgdnd3Mtd2l6EAMyBggAEBYQHjoHCCMQsAMQJzoHCAAQRxCwAzoCCAA6CAgAEBYQChAeOggIIRAWEB0QHlDNNFitV2DeWWgBcAJ4AIABdIgB3wqSAQQxMy4zmAEAoAEBqgEHZ3dzLXdpesgBCcABAQ&sclient=gws-wiz&ved=0ahUKEwiPmbecwbDvAhUOU98KHZxTABMQ4dUDCA0&uact=5
Have 2004 Jeep Grand Cherokee straight 6 starts and runs fine for about 10 minutes then starts getting hot ,smoke starts coming up where the intake exhaust to engine , when you acellerate the valves r
check the coolant level. check thermostat for correct operation. Have a compression test done to check for head gasket or cracks . All indications are that the motor is overheating badly.
Jeep grand cherokee 97 shakes slightly, check engine light one, slight squealing sound?
Go to Autozone,they will scan your Jeep for free,takes just a few minutes and they should be able to tell you why that check engine light is on.
Where is the idle located on a 1994 Jeep Grand Cherokee limited
It sounds like you do have a relay problem try switching relays around that have the same part number start with the starter relay when switching the make sure the key is off each time
2helpful
1993 jeep grand cherokee wont start till check engen light comes on
Your ecu computer is in need of repair. You have what is known as the Delayed Check Engine Light problem. There are a few components inside the ecu that are slowly failing and eventually will completely fail. The ignition has to be turned on, for a few minutes, and the jeep won't start until the check engine light eventually comes on. This is because the ecu feeds power to the fuel pump and injector relays and won't feed power until that light comes on. Have it repaired.
1helpful
Check engine light on,1997 Jeep Grand Cherokee,4.0 six cylinder.code 1757.cleared code,comes back on after a few minutes of driving. Trans is sluggish,when pulling out,after a complete stop.
I just had those similar symptoms with my 97 grand cherokee a week ago and my crankshaft position sensor had to be replaced...hope this helps.
1995 jeep grand cherokee barley runs after warmed up?
fuel system problem; filter, pump, injectors.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
