Question about Krups XP1020 Espresso Machine
My Krups XP 1020's frother sometimes sucks milk in instead of letting out steam. Is there any way to fix this? The milk then gets stuck inside the machine and goes bad, making the whole thing smell really bad.
SOURCE: Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
http://www.krupsonlinestore.com/manual/55360.pdf
Posted on Jan 10, 2008
dutchman05
  • 487 Answers
SOURCE: After moving from MI to
OK this is the problem which you see in more machines when not been used for a while.
you will have to prime the machine. As far as I know you can get warm water from this machine too. first decrust the brewing head as that can be one of the problems. if you still have the maintenance booklet it is picture 21 ( i think)
If this one is equiped with the warm water function press the hot water knob and let it run through. If not try to make a cup of espresso with fresh coffee. This should work
Posted on Apr 21, 2008
SOURCE: Hi, we have a Krups
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Posted on Aug 20, 2008
SOURCE: My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Posted on Apr 05, 2009
Krups milk frother xl 2000 will not steam milk. the lights just go from one to another with nothing happening
The unit likely has an electrical fault, my guess would be element not heating. Parts are available for them.
Jan 15, 2017 | Krups Coffee Makers & Espresso Machines
Why does milk frother blow out steam instead of milk?
That is what it is supposed to do. Take cold milk in a cup, and put the frother wand in it... Kind of bob it up and down for a few seconds, and the milk will froth.
Mar 01, 2016 | Coffee Makers & Espresso Machines
The frother on my krups 'il primo' has lost power. The steam barely comes out. How can I fix that?
I've also had this problem with the Krups 'Il Primo' - reduced steam for frothing of milk but plenty of espresso.
Diagnosis: over many uses, a residue of dried milk plugs the interior of the steamer tip.
Fix: Using a small adjustable wrench, remove the tip. Clean it inside and out with a tooth pick. Reattach the tip - gentle with the wrench.
Aug 01, 2012 | Coffee Makers & Espresso Machines
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Need replacement frother part for Nespresso Aeroccino
both parts can be found on amazon for about 9.99$. take a look here: Secura Automatic Electric Milk Frother and Warmer Whisk Set. I hope this was helpful. cheers
Sep 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
Krups XP1020 Espresso Machine Logo
69 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
