Question about Acer Aspire 3610 Notebook
Power switch does not work will not turn on - Acer Aspire 3610 Notebook
  • 674 Answers
Check the power button. or the current.. also the charger
Posted on Jun 28, 2009
1992 Nissan D21 , left turn signal dose not work , changed bulb and relay , still dose nor work. What next?
Next is probably the turn signal switch. If you have a voltmeter, however, you could be more likely to find the problem, using it to test for voltage at places in the circuit. So I guess you might also need a wiring diagram along with the voltmeter...
If you have neither a voltmeter or a wiring diagram, use logic to think the right turn works so the fuse is good, and if the right turn works, power is going to the switch, and out correctly for the right side, but seems nothing for the left, ( DID YOU CHECK NOT EVEN A BULB DIMLY LIT ON THE LEFT SIDE, FRONT OR BACK? AND ALSO THE LEFT TURN DASH INDICATOR IS NOT LIT?) If nothing lights up for left side, the power is probably lost right in the 25 year old turn switch. That's where you would check for power out (on the proper wires) with a voltmeter- no power means switch is bad. But if the power comes out of the turn switch for left side, then you have to look further along in the wiring , probably not far from the switch connector if the dash indicator bulb is also not lit....It probably is your turn switch.
Nov 25, 2016 | Nissan Cars & Trucks
1998 monte carlo brake lights dont come on
This is fairly easy to diagnose. Down by the brake pedal there is a switch. You may have to remove some trim panels to access it. There should be one wire with power all the time. There should be another wire that has power only when the brake pedal is depressed. If there is no power on any of the other wires with the brake pedal depressed than the switch is bad.
If there is power than the more common problem is the turn signal switch. I know it doesn't sound like it could be the problem but let me explain how it works. the turn signal and the brake use the same bulb. In order for the correct power source, brake lights or turn signals, to get to the correct bulb the turn signal switch is used. If you are not turning the power from the brake switch is routed through the turn signal switch and then sent to the two brake brake bulbs. If you are turning to the right power from the brake switch is cancelled to the right bulb and replaced by power from the turn signal flasher.
One quick way is to see if the third brake light is working. If it is you know the brake switch is working since power to the third brake light bypasses the turn signal switch.
Good Luck and let me know how it goes!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 14, 2015 | Cars & Trucks
98 chevy lumina Rear window break light works, but rear break lights don't, also right turn don't work?
I can almost 100% guaranty the turn signal switch is the problem. Power for the brake lights starts at the brake switch. power then splits from there and the third brake light gets power directly from the brake switch. Since the turn signal and the brake lights are on the same bulb power for the brake lights is routed through the turn signal switch. the switch depending on what position it is in will allow brake power or turn signal power to there respective left or right brake/turn bulbs.
If you hold your foot on the brake pedal and wiggle the turn signal and or play with the hazard switch the brake lights will almost always intermittently start to work. this will confirm a bad turn signal switch which is pretty common on GM vehicle with this style setup.
Apr 05, 2013 | 1998 Chevrolet Lumina
2000 tacoma flashers don't work but turn sig do work!
The hazard switch gets power from the horn fuse which is hot all the time, and from the turn signal fuse which is hot when the key switch is on. The turn signal switch gets power from the hazard switch and both use the same flasher.
So if the turn signals work but the hazard switch does not power the lights, and both fuses have power, I would say the problem is inside the hazard switch.
Feb 19, 2013 | Cars & Trucks
95 mustange gt brake light dont work check #9 fuses change all bulbs replaced switch on brake pedal hazards lights works ,parking or running lights works,turning signal lights works,what other places i...
I assume the fuse has power if the hazards work.
The third brake light skips the turn signal switch, the regular brake light circuit goes thru the turn signal switch.
Do you have power going into the turn signal switch on the red lite green wire from the brake switch ?
Feb 17, 2013 | 1995 Ford Mustang
A6119h power button doesn't turn on
if your want cpu run then open ur cpu change restart switch to power switch ...its work...
your power switch not be work
Jul 30, 2012 | HP Computers & Internet
2001 Town & country brake lights not working, but the third brake light and tail lights are working. I also just replaced the brake light switch thinking it was the problem, but it wasnt
I think the brake light and turn signal are on the same bulb on these, correct?
If so do the turn signals work?
If they do than I would bet that the turn signal switch itself is the problem. The power for the brake lights is routed through the switch (except for the third brake light that is supplied power directly form the brake switch). The turn signal switch will interrupt power from the brake switch and supply power from the turn signal flasher depending on if the right or left turn signal is engaged.
Sometimes wiggleing the lever or pushing the four way flasher button with the brake pedal depressed will intermittantly cuase the brake lights to work. If this is the case than it is the turn signal switch that is causing the problem.
Feb 11, 2011 | Chrysler Town & Country Cars & Trucks
I have a 1977 Mercury Grand Marquis the turn signals, brake lights, and turning lights do not work. The running lights and hazard lights do work. I checked the bulbs and the relay can for the turn signals...
Turn signal switch (also brake light canceling switch) most likely bad or bad wire to it or from it. Check, with key on run, for power into switch. Turn switch on, check for power out. No power out switch bad. Power out, trace to rear tailight harness for broken wire.
Jun 30, 2010 | 1977 Mercury Grand Marquis
96 monte carlo rear window brake light works but not brake lights. tail lights work, blinkers work, replaced brake switch and bulbs still not working
This is a common GM specific problem. Your turn signal switch contains an elaborate networking device that has to cancel brakelights while running a turn light. Often times the ground within the turn signal switch is lost causing your situation. After investigating such other possibilities as fuses and loose grounds it may become necessary to replace the turn signal switch. Thank you, Dana
Sep 21, 2009 | 1998 Chevrolet Monte Carlo
Acer Aspire 3610 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
