Question about Alpine CDA-9883 CD Player
Ipod won't get charge
Error1 came up and now the ipod works but dosen't get a charge from the connection. Any sugestions?
  • Anonymous Feb 01, 2008
    My iPod will not for some reason charge off of the cd deck. It use to when I first got it but now it just doesnt charge.
  • mrhout Dec 24, 2008
    i have the same problem. Please help if possible.
I also had this problem. What causes it is beyond me. But what worked for me is to do the following:
- Disconnect the IPod from the unit.
- Run the IPod to totally drain the battery (until you get the black screened apple)
- Open ITunes on your computer
- Synchronize your IPod and totally rechange the IPod before disconnecting it from the computer
- Hook it back up to the Alpine unit and you should be good to go.
Posted on Mar 09, 2009
See this accesory http://www.engadget.com/2008/11/21/scosche-passport-firewire-to-usb-ipod-adapter-gets-reviewed/ , the new ipods don't charge with firewire connections
Posted on Jan 05, 2009
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Sylvania imode ipod docking station plays ipod but won't charge it - why?
ipod touch has a light piece of plastic on bottom where it connects to the dock youtube has a video on how to remove it softly with a razor blade and once it is removed it will work properly although to be played through stereo i must have my ipod touch 4th gen on airplane mode
Jul 18, 2012 | Supersonic Audio Players & Recorders
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
What could be the problem if my iPod Classic won't charge?
Be sure to connect the charging/sync cable directly to the computer, not a USB hub. Most hubs are don't provide enough power to the usb ports to charge the ipod. If you need a method of charging the ipod while away from the computer connect your sync cable to a device like these: Even the USB port on Apple keyboards is not able to charge the Ipod.
If you're using the computer to charge the Ipod, be sure it stays on, when computers go into sleep or standby modes they stop charging your ipod. You may want to use one of the options below to charge your Ipod when the computer is off or in a different location than the Ipod.
For use inside: Best prices for a Belkin brand power adapter for Ipod click here
For use in the car: Best prices for a Belkin brand car power adapter for Ipod click here
May 10, 2011 | Apple iPod classic MP3 Player
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
Ipod not charging
hi Unpopster.
these links might help you find out why.
or this one.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices.
Dec 06, 2017 | Audio Players & Recorders
Alpine CDA-9883 CD Player Logo
334 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
