Question about Bosch SHU4006 Dishwasher
WATER IS RUNNING EVEN WHEN IT IS OFF
The water keeps running even when the unit is off. It is filling the bottom of the dishwater and flowing through the bottom of the door onto the floor. I had to turn off the water source to get it to stop. Is this a broken valve?
Thanks for your help!
  • 883 Answers
Yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Posted on Nov 07, 2007
I have mtr-2 dishwasher ..it is continuously showing the symbol for water filling and not going even water fully filled ..what should i do..bcz machine is not running....
You say it says water flowing. But, is it flowing? Does it overflow? If so it may be overflow switch on the bottom that got food stuff in it.
Mar 27, 2016 | Dishwashers
The water continues to fill the toilet tank even with the float at the very top
Sooner or later, that defective fill valve will have to be replaced.
May 05, 2017 | Moen Home
Even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
May 20, 2010 | Home
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Water won't stop running even when we turn the machine off it slows a little. i have to turn the water off to stop the flow of water.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Dishwashers Logo
130 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
