Question about Tools & Hardware - Others
Craftsman Router will not power on
I bought a used Craftsman router/table combo recently. Model 17508. Worked fine, was very pleased with it. When I took off the table recently to change a bit, I noticed that the power switch was held in the on position with a zip-tie (rather than the built-in lock-on button).
I removed it as I cleaned the unit and changed the bit, but when I finished it and plugged in the unit, it will no longer power-on. I completely took apart the unit, checked all the wiring, and everything checks out. Do I have a faulty switch box or could it be something else?
Thanks~
    Sergeant:
    Champion:
  • 207 Answers
You definitely have a faulty switch. I used to have the same router and had the same problem. I had to take the switch apart and clean it. I got tired of the unreliability and bought a new Milwaukee.
Posted on Jul 08, 2009
How to attach to my craftsmen router? I've inherited my Dads router, router table,and router guide. I have no idea how to use them. Will you please help me?
I have a craftsman router and table. On mine you remove all the screws from the base plate, set the base plate aside and use same screws to mount the router to the underside of the table.
May 08, 2017 | Saws
How do you install a ridgid router to a craftsman router table?
Brenda, They are just saying that if the router is too big, it won't fit. The sub-base is the plastic, usually black, disc on the bottom of the router. This disc is about 6 inches in diameter and about 3/16 inches thick. It is usually held onto the base of the router with three screws. The base is the big aluminum piece about the size of half a loaf of bread that has the handles and into which the router main part (the motor) slides into. For most router tables, you mount a router base (with the sub-base removed) to the underside of the table with screws. The router table becomes a giant upside-down sub-base. If your base fits, and the screw holes line up, you are good to go. However, it is very helpful to have an extra router base (without handles) to leave permanently attached to your router table so that you can easily swap the router between the table and normal use. Good luck!
Jan 13, 2013 | Saws
How to attach a skil router to a craftsman router table
I have done exactly the same thing. Craftsman Router table and Skil Router.
The problem seems to be the plastic foot plate on the router is bigger than the circular frame on the bottom of the Craftsman router table. On my Foot Plate, the holes seem to match up OK.
What I am going to do is take the plastic Foot Plate and router the edge down about 1/8 inch to make it fit in the frame. I have several Foot plates, so this is not a problem to reduce the size of one.
I purchased all of these items at different times from a 2nd hand store and thought (naively) that they should all be some standard to make them all fit. Seems like at least Craftsman has their own set of standards to make things difficult.
I will update this to let you know how it goes.
Apr 11, 2012 | Saws
Help, I have a Model 315.242130 Router. The motor housing body(plastic) has been worn thru use and when I had it attached to my table saw with router attachment(also sears) it became clogged with wood...
These were made by Diehl Manufacturing Co In 1988 the Motor Products Division of Diehl was acquired by Japanese power tool maker Ryobi, Ltd., becoming the basis of Ryobi's new U.S. operations, Ryobi Motor Products Corp.; Ryobi took over supply of products to Sears Craftsman, retaining the 315 manufacturer code.
So... it appears you can use a Ryobi part. this may sound sarcastic but.. even as a seasoned expert we could spend hours searching ryobi router parts and still not find you a 100% match.
Spend some time using this page and see if you find a match:
http://www.ereplacementparts.com/ryobi-router-parts-c-7931_8117.html
Click on the individual corded router links.
Just trying to help you,
Kelly
May 25, 2011 | Garden
Manual Craftman professional router table model
I have a Craftsman professional router table, laminated model 26608. I can not find a parts manual for this item. I tried a number of way to find parts for this item. I believe this was made by Bosch. I can not purchase a Router table mounting plate for this item. it measures 7" x 8". with a center hole of 3". also 3" insert rings. Bosch and Sears makes items for a professional router but the center hole is 3 3/4 inches and the plate is a lot larger in width and length. I have gone to Bosch on the internet and came up with a model RA1171. This is a model like the one I purchased; however, they have changed the size of the adapter plate and the center rings. the model no. they show is 29LCN1428.
Dec 31, 2009 | Craftsman Milescraft 1207 Turnlock Wood...
Need booklet showing how to use table with router
Here's a link with a few basics: click here.
But your best bet is to search the library in woodworking magazines like Fine Woodworking, American Woodworker, etc, etc for past articles on router tables and router projects. Also read the reviews, (like this one) of router tables currently available and you'll get an idea of how to set up featherboards and fences and vacuums to make the most of your work.
There are also some online router forums and guides that will shed a lot of light on common problems and solutions, see here and here
Or do a google search on routers + woodworking.
You'll turn up more info than you can digest.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Tools & Hardware - Others
I am looking for an owners manual online for a Craftsman 600 woodworking router, model #315.240040. Can you assist me
Sears does a horrible job of getting this info out, but here's a link to their site with all the manuals for Craftsman power tools.
http://www.managemyhome.com/mmh/owner_manuals
Enter the entire model number and search. If that does not come up, just enter the 5-digit number - often the last 5 digits.
For exampel - I have a Craftsman router, model# 135.17508. That returned no solution, but when I just entered 17508, the manual came up.
Hope that helps~
Apr 23, 2009 | Craftsman Tools & Hardware - Others
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Feb 18, 2009 | SMC (SMCWBR14-G2) Router
Tools & Hardware - Others Logo
303 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
