Question about Microsoft Xbox 360 Console
My xbox 360 still doesnt work
I have tried the towel trick tried holding y for 2 sec and pulling the right trigger while still holding y and my xbox 360 still doesnt show picture but you can still here the sound
  • 767 Answers
Yes its an x clamp mod, just a tip
the dead video x clamp mod requires
a little more heat than the the C.P.U
can put out to self correct ,so make
sure the person who does the mod
has done this type (non video x mod before)
F.Y.I
Posted on Jul 02, 2009
  • 90 Answers
It's a simple X-clamp fix. Hit me up at console.mods@yahoo.com
How do u fix the three red flashin lights on the 360
(do it on your own risk} it has 70%chances to problem solved.
it is just a trick dont blame me if anything happend
try to unplug all wires and replug ***
1. run xbox for 1/2 hr
2. wrap (cover) ur xbox in towels , wait until it get switch off by itself(due to over heat)
3. unplug the xbox , shake it in all direction for 10-15 sec , hit slowly on both sides of xbox
4. now switch it on , if u find any red ring then, cool the xbox using (a/c, fridge ) not for too long.
i think the pro will solved
Mar 05, 2010 | Microsoft Xbox 360 Console
How to fix my xbox 360 from 2 red lights
Towel Trick This part is more for reference. I don’t recommend doing this method.
I read about the towel trick before I found out about the X-Clamp replacement, so thought I would give it a try. At the time, it was either this or the heat gun trick, which seemed a bit more risky, so I went with the towel method.
This method basically involves wrapping your xbox 360 up in a towel to prevent any airflow from getting in, or out, of the xbox 360. This in turn forces the xbox to get really hot. You must leave the video plug attached, so that the xbox does not auto shut off. I left it running for about 15 minutes. It got pretty warm...
I’m not sure on the specifics, but I believe this just allows the solder on the cpu/gpu/ram to reflow, and fix the bad connections. As the x-clamp is still in use, this method generally will fail, and it did for me after about 2 days (and I wasn’t using it heavily).
Dec 14, 2009 | Microsoft Xbox 360 Console
I have also tried the xbox on different televisions
as the console starts
press and hold the y button for 2 sec
then pull the right trigger but dont release the y button..
if your successfull, the console should restart..do it a couple of more times...
what you are doing is trying to reset the display to defaults
Jun 27, 2009 | Microsoft Xbox 360 Console
When i turn on the xbox 360 one light on right side goes on
This is called the ring of death. It happens to alot of x360. The console got to hot. One thing you can do is the towel trick. Wrap the 360 in a towel so it is not exposed at all. Make sure it is turned on. Leave it on for 30 minutes. This sometimes will repair the problem. If this does not work the first time try it again. If this does not work there is another fix, but it is very involved. Let try the towel trick first.
May 29, 2009 | Microsoft Xbox 360 Console
No screen on the Xbox 360
right do the towel trick it works. wrap the 360 in 2 towels and leave it on for 15 mins. then go bk to your xbox un wrap it. put it near a window if possible ( i did and its working fine) due to it being near a window you will get no overheating and its well ventilated.
Dec 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 Red ring of death
If it still under warranty, contact Microsoft for a replacement.
There is no permanent fix for the Red Ring of Death.
Sep 01, 2008 | Video Game Consoles & Games
XBOX 360 no picture
try diffrent connectors composite instead of componant or vis versa. the wireless for the controls doesnt work on mine. I havent been able to find alot of replacement parts for the 360. I think you will end up having to send it in or by a used Core system for $200 from ebgames or ebay.. You could also try holding down the power button for 10 seconds. i heard that resets it as well.
Jan 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 no video but have audio after playing madden
Something to try is just leave the xbox on for an hour, turn off let cool for 5 min. If that doesn't work, it's a difficult solution to recommend but the towel trick' does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jan 03, 2008 | Microsoft Xbox 360 Console
No screen or picture but theres sound
You may have a bad video cable, remove it and re-attach it. Make sure no pins are bent. Try cleaning the contacts.
If you have another cable try it.
Possible bad video output IC
Check here if that did not fix it.
Nov 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
141 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
