Question about Durabrand DWT1905 TV
Picture is fine but sometimes no sound
The volume is at 100 and you can't hear the tv unless you hit the sides.but later the sound goes away again.can this be fixed?
  • 458 Answers
Yes, this looks as if you have a bad connection somewhere in the audio stage, this should be able to be fixed by a simple re-soldering.
Posted on Jun 28, 2009
MY Panasonic TV Model TX -33P100X showing half picture and half black screen. When switch off and on again sometimes the picture reappear.
hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints ...........
Jul 29, 2011 | Panasonic Televison & Video
JVC AV32920 Horizontal black lines running thru picture. Picture condenses to a single horizontal line in the middle of the screen, audio is fine. When I bang the sides of the set (old fashioned manual...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer ........good TV service engineer will charge very less ...absolutely there is no need for new TV........if soldering joints are properly soldered then your TV will work for 1 more year ( minimum )......iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
May 12, 2011 | Televison & Video
Display setting out of focus
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Sharp 20N-S100 20" TV
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Symphonic WF27F4 (an old tv??) How to restore the video which is sometimes just a horizontal bar or line, and if you hit a good wallop it may recover the picture for an hour, a day, or a week until it...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 19, 2011 | Symphonic ST427FF TV
About 2 inches of the top of my screen won't show. Sometimes it will turn into a line that runs through the center horizontally. If I hit it it will go back to normal except still missing the top 2 inches
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again (2inch on top will also gets solved )................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 18, 2011 | JVC Televison & Video
Picture is small box upper right hand side
when picture is getting smaller in size or goes away or moves towards one side ( like yours) then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some CRT computer monitors & CRT TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re- soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 17, 2011 | Daewoo DTQ-20U9SC TV
The screen seems like its fixing to go out! The picture starts off normal size then gets smaller and almost goes completely away!
when picture is getting smaller in size or goes away then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some CRT computer monitors & CRT TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size & disappears...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re- soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 16, 2011 | Disney DTD1363-CAR 13" TV/DVD
Durabrand DWT1905 TV Logo
55 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
