The unit will not turn on
The ac unit will not turn on
  • thetim May 11, 2010
    Is it blowing any air at all when you put fan on the on position at the t-stat? Could be many things. Is the emergency switch on the on position? circuit breaker,Disconnect had fuses,bug in the contactor,broken 24v wire.................
  • 146 Answers
Need more data then that. if it is central A/C take look at fuse next the unite or the breakers.
Posted on Jun 28, 2009
Turning on heater the AC unit kicks on. When using AC it won't turn off, just runs and runs and runs. Would this be an issue with the thermostat?
find where the thermostat bulb is located
if it is the ceiling or unit , it requires the unit to fill to the roof with cold air before it turns off
as most rv units are not insulated , the unit seldom fills with cold air enough to turn it off
I would get an accredited ac shop to check it out
Oct 20, 2015 | Dometic Rooftop RV Air Conditioner
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
I have a TRANE XR12 central AC UNIT, when i turn my thermostat on i get a click sound and ac unit does not come on. i checked the circuit breaker to make sure it's on.i have not turned this ac on for a...
There is a time delay on the stat to the AC unit, in addition the AC unit likely has one also, so immediate activation as desired isnt likely, however in 10 minutes of asking for AC if its not on still Id check the time delay fuses in the service disconnect at the AC unit, its a small grey box with the power cords running to and from it, there is 2 time delay fuses inside this box.
Jan 12, 2011 | Heating & Cooling
We turned the ac unit control knob in between the high cool and low cool, which turned off the ac unit, but messed it up where it shorts the circuit breaker when we try to turn it back on. What did we do?
YOU MIGHT OF JUST SHORT CYCLED IT . ALL AC UNITS NEED ABOUT 3-5 MIN TO EQUALIZE PRESURE ON COMPRESSOR BEFORE RE STARTING  . IF THIS IS RV AC MAKE SURE YOU HAVE WELDING TYPE EXTENSION CORD
Apr 22, 2010 | Dometic Rooftop RV Air Conditioner
Car turns off if ac or window deforst turn on even low setting
Well, The problem seems to be the AC unit. When you activate window defrost the ac unit also activates for some reason. Disconnect the wires from the AC unit and turn on the defrost, if the engine doesn't stop then you know that is the problem, if it does die then you have a vacum problem.
Oct 09, 2009 | 2003 Ford Focus
Ac unit not turning on
Chances are your A/C unit can be repaired for a lot less than a new one -- I'd call for service.
May 07, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
