Question about Breadman TR555 Deluxe Rapid Cool Touch Bread Maker
Breadpan for the breadman leaks water
When I put the water in the pan and before finishing adding the flour 1/2 the water has leaked out where do I go to replace the PaN
part number 20101
Robert LeBorne
robertleborne@cox.net
You will need to order a new bread pan. When I had to do this, I had to get it from the breadman/salter company by finding and calling their customer service #.
Until then, you can mix your ingredients by hand in a bowl until most of the wet is absorbed, then transfer to the pan and turn the machine on. You can limp by 'til the new pan arrives.
Posted on Aug 25, 2009
Inner pot leaks
as long as you are not using the delay timer. It is OK to put the flour, salt, sugar etc. in and put the liquid in last. As soon as you pour the liquid in push the start button. If your pan only leaks a little the fact that you are mixing right away with the flour on the bottom now will prevent any leaks. The only other answer it to replace your pan and they run about $20.00 After you push the start button don't forget to add the yeast in too.
Oct 23, 2013 | Breadman Kitchen Appliances - Others
Tip
Using an Automatic Bread Machine
There are several videos on YouTube about how to bake a bread in a bread machine. Several show the demonstrator pouring liquids, flour oil etc. into the bread pan when it is in the bread machine. This a mistake. You should never be pouring ingredients into the pan while it is in the machine. If you spill milk, flour, oil, butter, etc. it will drip down on the the drive of the machine, onto the heating element etc. Down there it will gum up your drive, smell bad on the heating element etc. You can easily clean a stove burner. You CAN'T easily clean the small cook chamber and drive gear on your bread machine. ALWAYS REMOVE YOUR BREADPAN FROM THE MACHINE BEFORE ADDING YOUR BREAD INGREDIENTS THEN CAREFULLY PLACE THE BREADPAN IN THE MACHINE AFTERWARDS! YOUR COOK CHAMBER (OVEN) WILL BE MUCH CLEANER AND YOUR MACHINE WILL LAST LONGER.
on Oct 13, 2010 | Kitchen Appliances - Others
Leaking breadpan need to replace the gasket?
You would be better off just replacing the pan. If you need an online source just email me
Jan 15, 2011 | Breadman TR888 Corner Bakery Bread Maker
How many pounds does the trillium tr-500 bread baker make? 1 or 1 1/2 lbs?
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Nov 27, 2010 | Breadman TR500 Bread Maker
Kneading problem - lop-sided loaves
it is very imporant that you put the ingredients in the right order (water on the bottom, flour floating on top o it, yeast on the flour not touching the wwater). Also the amount of water is crucial.
The bread becomes evenly distributed during rise.
Rise problems might be due to improper kneading which in turn might be due to the pan jumping. Check that the pan is not jumping during kneading.
Jan 08, 2010 | Breadman TR2200C Ultimate Bread Maker
I am also in need of a pan for my breadman 2200C.
If I cant get my breadman ultimate tr2200 fixed, I can ship you my breadpan. I guess that would be better than throwing it out. It is like new.
Jul 20, 2009 | Breadman TR2200C Ultimate Bread Maker
Need the operting Manual for PerfectBaker PB571
Here's some info;
http://www.creativehomemaking.com/download/TR888_1183_Recipe_Book.pdf
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Apr 25, 2009 | Breadman TR888 Corner Bakery Bread Maker
Where can I find a replacement breadpan for the breadman tr2200c?
I found the part at
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
http://www.saltoninc.com/
Nov 13, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadpan Stuck
Put your breadman on a surface low enough that you can look straight down on the pan and the machine.
On each side (L/R) there are thin aluminum "wings" that hold the pan in. The pan should be placed straight down and pulled straight up.
Adjust if you can-do remember that there is a "peg" in the center of the machine, so don't break it.
I had to fuss a little to get it straight and then lift it out.
Apr 30, 2008 | Breadman TR875 Bread Maker
Breadman TR555 Deluxe Rapid Cool Touch Bread Maker Logo
250 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
