On certain of the letter keys on the keyboard when you press them it types a number. on those letter keys there is a number in the upper right corner. how can you type the leteter. thank you
  • 49 Answers
Is the number in the upper right corner a different color? There might be a key you can press that changes those letters from the letter on the key to the number on the key.
Posted on Jun 29, 2009
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Disable fn key on a
If the FN key cannot be dis- engauged you will need to replace the keyboard on the laptop.
Mar 17, 2012 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
When I type letters or numbers using my key board nothing appears on my Desktop. Microsoft Basic Keyboard When I type nothing prints out I disconnect it and re connect it still has the same problem.
if your using the numbers keypad to the right on your keyboard, it sounds like you need to press the numlock button to activate the keys. if thats not the case , you may want to replace your keyboard if this is an issue that involves the upper number keys above the qwerty board.
Jan 17, 2011 | Microsoft Computers & Internet
Definition for keyboard
As the name implies, a keyboard is basically a board of keys. Along with the mouse, the keyboard is one of the primary input devices used with a computer. The keyboard's design comes from the original typewriter keyboards, which arranged letters and numbers in a way that prevented the type-bars from getting jammed when typing quickly. This keyboard layout is known as the QWERTY design, which gets its name from the first six letters across in the upper-left-hand corner of the keyboard.
While the design of computer keyboards may have come from typewriters, today's keyboards have many other keys as well. Modifier keys, such as Control, Alt/Option, and Command (Mac) or the Windows key (Windows) can be used in conjunction with other keys as "shortcuts" to perform certain operations. For example, pressing Command-S (Mac), or Control-S (Windows) typically saves a document or project you are working on. Most of today's computer keyboards also have a row of function keys (F1 through F16) along the top of the keyboard, arrow keys arranged in an upside-down T, and a numeric keypad on the right-hand side. Some keyboards have even more buttons, allowing you to change the system volume, eject a CD, or open programs such as your e-mail or Web browser.
Nov 05, 2010 | Computers & Internet
Letters are typing as numbers
one of the F keys turns certain keys on the right side to number keys, so it can act like a full size keyboard with the 10 key panel on the right.. Look carefully at the F keys to determine which one it is. Or consult the manual.
Aug 31, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Computers & Internet Logo
267 people viewed this question
David Payne
David Payne
