Question about Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
My Series P4E pump will run for a couple of hours then shut off. After about 15 minutes, it starts back up again. This is our 4th season and this has never happened before.
  • 83 Answers
That sounds like the motor is getting too hot. There is a safety feature in the pumps that will shut it off when the motor begins to over heat. When it shuts off, does the motor feel hotter than normal runnng? DO NOT touch the motor because if it is hot it may burn your hand.
Things to look for that may cause this issue:
Air in the pump basket area. If there is a small air leak, the motor would be working at the same rate, but not moving the same amount of water.
Too high, or low, of pressure on the filter gauge. If it is too high and you have not cleaned the filter yet, try that first. If you have cleaned the filter and the pressure did not go down, you may have a blockage somewhere in the system. If the pressure is lower than normal, you are not getting the flow of water through the system as before. This could be a blockage from the main drain/skimmers to the Inlet on the filter. Or, an air leak.
Posted on Jul 10, 2009
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Steiner lawn mower
Might be Coil Breaking down under heat. Not sure best way to diagnose other the cross your fingers and buy a new coil. Sounds like you did everything you could do Fuel -wise.
Oct 02, 2012 | kawasaki Garden
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Jul 30, 2010 | Dolphin Maytronics Advantage
Pool pump shuts off after a couple of minutes and seems to be hot
You problem could be one of several things. First, pumps have a thermal protection switch that shuts the pump down when overheated. You could have rust after only one season that overheats the pump and it shuts down. The switch could be bad. There could be an electrical issue when running it on a long cord of the wrong gauge. Plug the pump into an outlet without extension cord and see if it makes a difference.
Apr 18, 2010 | Pool & Spa
Tractor will shut down and will not start up again
Three things, replace air filter, replace fuel filter, and take carb off and clean it out, could have sediment in jets or float is sticking causing not enough gas to run through stalling out motor.
Aug 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed Logo
106 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
