Our drain seems to be blocked with dirt or something as water is collecting in the drain pan instead of draining properly.
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
SOURCE: The drain hole is in the window sill, not the back
I'm not sure why that drain hole is located where it is - but in any case - you're going to have to plug the existing hole and re-drill another drain hole at the back of the unit.
I would plug the unwanted hole with a 'liquid steel material,' i.e. JB Weld or something similar.
Note: be careful when re-drilling the new drain hole and don't drill a hole in your condenser.
good luck!
SOURCE: My FAC104 P1A window air conditioner does NOT
Some don't have a drain hole anymore. As long as you have it tilted slightly, any excess water will drain out. If your house or room feels good, it's working. It won't pull moisture out of the air if the air has already been dehumidified.
SOURCE: THE DRAIN HOLE FOR MY FRIDGIDAIRE AIR CONDITIONER
You will have to remove the unit fro the window,and take it outside and remove the cover,unless the sheel remains in the window,and use a water hose to clean all the debris out and clear the drain,this really needs to be done every year,also,make sure the tilt on the unit is enough for the water to drain outside,not in,if this was at all helpful,please rate thank you.
SOURCE: My frigidaire air conditioner is
The tray that holds the condensed water from the evaporator
may be clogged, it may be clogged before the cleanout hole,
where the tray joins the pvc, if this is the case you may have to
power down your ac unit, there is a panel on your heater unit
that you will have to access to expose the evaporator coils and
you will see the tray where the condensation builds up and flows
thru a pvc pipe to go outside. also make sure that the pipe going
outside is at a slope so that the condensation can flow and not
clog the pipe. make sure that water can flow from the tray thru
the cleanout hole. once you correct the problem. you need to reseal all the seams with duct tape or metalic tape, you can purchase at most hardware stores, to make sure their are no ac
cool air leaks other than thru your ac vents. good luck!
