Question about Garden
Battery has full charge, has a clicking noise around mower deck up front when turning key. Sounds like a solenoid kicking in but not turning the starter, soenoid is okay, starter is okay. Is there a safety switch near the drive pulley for the mower not to let the start.
  • 513 Answers
The safty switch is on the braking pedal under chassis check that safety switch if the switch is good check battery connections let me know if i can further help thanks wade
Posted on Jul 04, 2009
I have a spider box yerfdog 3206 wt i believe 150cc howhit engine. Won't start solenoid clicks but no power to starter. even direct power to starter wt solenoid bypassed starter won't kick in ? I have
this sounds like the starter is no good that`s why you get a click noise and why bypassing the solenoid it won`t turn over. the armature must be drawing more amps than what can be supplied.
Sep 21, 2014 | Cars & Trucks
My craftsman yt1000 23bhp, i have been jump leading my mower for around 6 months now, i started my mower last night no problem but got up this morning, turned the key and it just buzzed. so i origonally...
check the solenoid if you been jumping it off you could have burned it out and possibly the starter replace the solenoid first thats the cheap route and if that dosnt fix it check the starter if its buzzing or clicking its gone bad feel if it get hot if it does thats the bad sign to look for, replace solenoid, then starter thats my advise need more info messege me back for more, thanks, jamie
Dec 27, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Riding lawn mower stopped working, now it just makes a clicking noise when you turn the key, the grass was pretty high when this happened...did the engine blow?
clean the battery posts for one, and make sure the unit has a full 12 volts in the battery ,, these units charge slowly as it is, and if the battery gets to low, the machine will just quit, you try and start them, and all you get is a click
Jun 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
Mower won't start. Makes clicking noise.
Check the battery terminal connections for cleanliness and that they are free of corrosion. If the contact is corroded, this is what the clicking would be from.
The battery could be charged, but if the connection is dirty, the power won't be able to engage the solenoid properly.
Hope this helps.
Jul 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
When I turn the key I get a rat-a-tat noise. Battery is charged
sounds like the starter is stuck or not engaging or the solenoid is faulty,, first look for a bad earth from the engine to the battery or loss or dirty battery leads
Jul 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Jump solenoid with screwdriver
Turn key to run. Put screw driver to battery cable side while holding the plastic end of screw driver touch other end of screw driver to cable that goes to starter on solenoid and wjth full charge of battery you should have starter turning.
Mar 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Aug 11, 2009 | Briggs & Stratton Garden
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
