Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
After 20 to 30 mins of mowi ng it stops and wont go foward or rev
After it cools down it will do it again
    Problem Solver:
  • 12 Answers
Try running it with the fuel cap off . the vent in the cap could be clogged.
Posted on Aug 09, 2009
  • don c Aug 19, 2009
    Also check the solenoid on the bottom of the carburetor. Quick and easy way to check for this is When the motor stops remove the air cleaner cover and filters. Use starting fluid or brake clean and spray some in the carburetor opening then try starting it . if it starts then the solenoid is bad. only after trying the cap thing.
Toyota hilux d4d starts well when engine is cold but just cranks and wont start when engine is hot. will start again without problems when engine cools down say after 20 to 30 minutes.
Poss temp sending switch or coolant sensor NG. Have computer scanned & readings on sensors read. Check coolant, make sure up to level.
Feb 24, 2017 | Toyota Hilux Cars & Trucks
Got a 2002 ford windstar. the vehicle is in gear but jus keeps reving up. them shut it off than back on n it will drive foward and reverse than stop n when tryin to drive again it will jus rev up again n...
The transmission filter is stopped up. Change it and add some new fluid and "trans x" conditioner and hope for the beat. Otherwise you need a transmission.
Sep 18, 2014 | 2002 Ford Windstar Cargo
Air conditioner model # A6T12F2A REV. A is cooling ok for a 2 to 3 min. at a time then it kicks down and blow warmer air out almost like it is reading like the room is cool and stops cooling maybe...
leave the unit off for about an hour to let cool off its hot and kickingout on the over loads . this is probley realted to a power problem or low voltage problem in you area due to demand
Jul 24, 2011 | Fedders Heating & Cooling
Morning or when engine cools down I have to run it for about 15min then it stop dead. wait for 5-10 mins, turn it on and runs again for 2-5 mins than stop again. wait for few more mins and on again, It...
dear sir
this can be problem cause of o2 sensor(lamda sensor) . in cold condition if we start the car some quantity of water can also came out through silencer and can stay at point of 02 sensor it is paced at silencer, ECU(Engine Control Unit) receive data from 02 sensor for Engine Firing . so replace it and let me know. thanks.
Sep 13, 2010 | 1997 Jeep Grand Cherokee
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
137 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
