Question about NComputing L230 Network Terminal
I've got 3 L230 Terminals all ask for a password I never set.
After setting up the first terminal,when connecting to the Server it wants a password.I never setup any password and when ypu click ok,it says wrong password.Then I configured the 2nd terminal and the same thing happens.Under setup I've got no password required ticked.This is frustrating me as I want to get the 2 terminals talking to the server.Please help.Thanks.
Try to add users with password on your windows 2003 server first and test and see if this resolve your issue you c
Posted on Oct 08, 2009
How to reset setup password for L230 NComputing?
Hello it would be easyest to download the manual:
http://www.ncomputing.com/kb/L-series-User-Manual_364.html
You need adobe reader, to read the content.
Good luck
Jan 15, 2013 | NComputing L230 Network Terminal
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Hi
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
One terminal cannot connect to the main server even if i connect through ip address or name of server. please assist me as soon as possible.
Are you getting an error message? If so please post what that error is so I'm not falsely guessing what it might be. As a test, make sure your server can PING the L230. You can see the L230's IP address in the configuration console.
Aug 05, 2011 | NComputing L230 Network Terminal
Model ncomputing L230 host un reachbull eror coming not conneceting. please immediately solve the problem and give us reply immediately mob:9963266130
The L230 does not have a full IP v4 stack in it so having it connect across Class A subnets can be a challenge. Try to get the Server and the hosts on the same subnet.
Jul 16, 2011 | NComputing L230 Network Terminal
Ncomputing cannot connect to the win server 2008
Please specify which Server 2K8 version you're using. If it's W2K8r1, and you had installed SP1 as of this posting date, their software didn't support SP1. They recently updated vSpace to support that so please either remove SP1 and retest, or update your vSpace software to the current version and you should be all set. Additionally, if you're server/host is a domain member, make sure it's a domain member when you install vSapce as the installation will manage the firewall port settings for you and many times those firewall port settings change when a system as added to the domain membership.
May 25, 2011 | NComputing L230 Network Terminal
My n computing terminal server windows 2003 is getting restarted , i have connected around 15 users please help me to solve this problem.
It is getting restarted on it's own? If so, it sounds like you have a driver conflict and you've setup your system to simply restart when there is a crash. Enable the crash dump to capture the Blue Screen information the next time the server restarts. Please provide the version of vSpace you're using.
May 06, 2011 | NComputing L230 Network Terminal
Ncomputing server 2003 hang problem when user (L230) login to server
Make sure you're on the latest vSpace software for W2K3, that version is v4.9.5 and is available on their download site. The issue you mentioned will be resolved if you update your software and register it. Make sure to enable bakground hardware activation in the system settings. That's managed through the vSpace console.
Apr 25, 2011 | NComputing L230 Network Terminal
I am having conflict ip in DHCP mode, I set a static ip still not list the server and not communicate with the network, how do I reset the device to factory settings?
There is no factory reset. If you set a static IP Address, you should be able to PING the L230 from another device on your network, i.e. the server. Please test that. Make sure the static IP address you assign to it is in fact available. Moving forward, it's best to turn on the Gratuitous ARP for your DHCP server so that it will verify if an address is already being used BEFORE giving it out.
Mar 12, 2011 | NComputing L230 Network Terminal
How to reset password on L230
Hold down the reset button for at least 30 seconds will usually reset all settings.
Oct 23, 2010 | NComputing L230 Network Terminal
NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Aug 13, 2008 | NComputing L230 Network Terminal
NComputing L230 Network Terminal Logo
664 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
