Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Refridgerator does not cool
When plugged in, the lights come on when the doors are opened and the fan runs but the refridgerator will not cool. The compressor does not come on. I hear a click under the refridgerator about every 30 seconds or so.
  • 473 Answers
It has a bad relay on the compressor. Looks like your model is a 50552 Kenmore. If so the part # you need is a 8201799 (start device) cost is $45.96 and you can get it at or any local appliance parts house. It is # 16 on this diagram
Posted on Nov 07, 2007
Its likely that the main transfer and power is blown out, like my fridge.
Posted on Dec 08, 2008
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
No cooling
Look at the back wall on the left hand side. "near the middle shelf"
If you find a wet spot or ice ball odd are you will need a Evaporator coil.
See if the fan is running when you open the door. By pushing the fan and light switch closed. "light will go out, Fan should come on" easy way to see if thermostat is telling the compressor to run"
Sep 03, 2012 | Sub-Zero 561 / F
Refridgerator running for long periods of time
clean coils make sure light goin out when door shut open freezer control by setting to a lower number
it will allow more air to enter refrig thus shuting off tstat also if fan cooled condenaser make sure fan in ronning and back is on unit for prper airflow
Feb 02, 2012 | Samsung Refrigerators
Hi my refridgerator is not cooling and the fridger section is also not working, every thing is been melted. we can here the refridgerator running but its not cooling.
b44df16.jpgIs the fan motor running below and the coils clean? 8dff5ce.jpg6e3f9f7.jpgIf nothing is running but the light is on you might have a stuck defrost timerb365bb7.jpg
Aug 30, 2010 | Kenmore Refrigerators
Refridgerator and Freezer Not Cooling (2 year old fridge)
Some of these had problems with the door light switches between the doors. They also control the fans. The top and bottom both have fans in back. Try opening top door and holding door light switch in. Wait for a couple minutes to see if fan comes on. Try with freezer too. If not coming on may need switch.
Jun 02, 2010 | Samsung RB215LASH
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
232 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
