Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
F 21 code flashing on are whirlpool duet washer
F 21 code flashing on are whirlpool duet frontloader washer. also the clothes are still wet comming out after the wash us done.
  • 20 Answers
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer, clothes dripping wet
set it for a drain/spin cycle and watch it 12 min. doesit sound like the pump is kicking on???? if so is it removing water??? (you should hear it or see it exiting out hte drain hose.) next is it actually spinning at full speed by min 7 in the display it should start ramping up to the final full rpm spins, usually faults out if there a problem with unit itself, otherwise its a user end issue. you ARE usinf HE detergent right? not just a little less of regular soap! although it sounds good HE detergent actually designed for yuse qith the frontloading products, too much suds causes , no hide speed spin aas well as a SUD in the display
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
650 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
