Question about Dell Latitude D505 Notebook
Hi, I have a dell d505 laptop and am getting a dst short test error when running the diagnostic. someone told me I should run the recovery cd, but I no longer have it. How can I get one ? Is there a way to download it ? Thanks
  • 3,940 Answers
You can download Dell Diagnostics from Support.dell.com for your model system, and see if you get a failure indication there. If you get a failure during Dell Diags, then it should help you ID the failed component. If the Diags pass, it is only indication it didn't FIND a failure, so there still MAY be a hardware issue. (Diagnostics only look for a limited selection of possible errors, so failures may still exist, even though a component passed a diagnostic.)
If you are having a memory issue and have two ram modules, best test is to try each module in the system by itself and see if issues go away, if they do, then the one module that generates errors is likely bad.
Posted on Jun 29, 2009
Computer boots up but then goes into a black screen I have run a Dignostic on it and I get an DST Short Test Error Code 100-0146. This is a Dell Latitude D600. Thanks In Advance
This error indicates that your hard disk drive or the circuitry that controls the hard drive is defective.
Either your hard drive is defective or the motherboard.
Try running diagnostics form a CD on your computer. You should have a CD that came with thecomputer that has "Diagnostics and Utilities" listed under contents.Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com andselect "Drivers and Downloads". Enter the "service tag" (serialnumber) of the computer. You can then download "Diagnostics" .
To boot from a CD disk, power on your computer and tap the key tobring you to the "One time boot menu". Insert the CD into the top CD/DVD driveand then select "Boot from CD/DVD" and hit key. Select the"Run the 32 Bit Dell Diagnostics.
If you are able to run the Diagnostics then your hard drive is probably defective.
Aug 02, 2011 | Dell Latitude D600 Notebook
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Aug 16, 2009 | Dell Latitude D610 Notebook
Failed DST Short Test and Screwy Mouse/Keyboard
Hi there.
I'm sorry to say that error code 1000-0146 means that the hard drive is failing and it can go at anytime, get yourself a USB mouse and start the computer up, the operating system should recognize the mouse and install the drivers (it may take a couple of minutes so be patient), as soon as the mouse is installed it is imperative that you back up all of your data, either to an external drive or CD/DVD.
Then you have to purchase another dive of if you have any warranty on the laptop send it in for Dell to repair.
If you are out of warranty and need instruction on how to install a new drive please feel free to post back.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Dell Inspiron 6000 Notebook
No screen visible
run win xp boot cd and access recovery console... run chkdsk... hit y when it asks you to... another way of doing this is right click on ur hard drive and choose properties.. tools... disk check... choose both the options asking for complete scan etc.. itll then say that scan will be done when windows is restarted.. say ok.. restart...
Nov 20, 2008 | Dell Inspiron 8600 Notebook
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D505 Notebook Logo
181 people viewed this question
Alun Cox
