Question about Teletype Gps WorldNav 3100 Deluxe Portable GPS GPS Receiver
My gps keeps saying mapping system fail, how can I fix it?
    Brigadier General:
  • 4,090 Answers
Only fix is to reinstall
Posted on Jul 01, 2009
I purchased Garmin1490t and it says "Cannot unlock maps" / 'No maps Found" Please help
If your Nüvi keep displaying the maps are locked, you will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then 'My Computer', and double click on your device file (mass storage system), there you will see a folder named 'Garmin'.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Other choice, could be one read at No Detailed Maps Found That Support Routing
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Garmin nuvi 255W GPS Receiver
My GPS keeps saying cant unlock maps after i already loaded maps on it
The Garmin Maps require a map unlock code in order for the GPS to be able to open/access it. Since the maps are copyright protected by Garmin you should of recieved the unlock code from Garmin when you purchased the new map update.
Mar 07, 2010 | Garmin GPS
My garmin keeps saying loading maps every time i try 2 use it and not working
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Dec 03, 2009 | Garmin nuvi 200W GPS Receiver
Pin570 using garmin Mobile XT software,GPS not working
Try Start Settings System GPS and tap ON before starting the satnav program. Not all programs automatically switch on the GPS. On hitting ON yellow light top left starts flashing. Now start your satnav program..
Aug 08, 2009 | Navman PiN 570 GPS Receiver
Freezes and says load bitmap fail
you contact your bf who goes and searches the error you gave him which takes him to the question you posted online the day before
Aug 05, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
No map available
It is quite likely that any maps you obtain from others will not work in your GPS as maps are coded back to component parts in the unit ANTI PIRACY codes .Similar to MS serial numbers. It reads ID's and checks against those stored in map. The only option is to purchase new maps for the area you want.
Jul 24, 2009 | Magellan RoadMate 800 GPS Receiver
Sony NV-U73T
Yes. You should ask for the free CD to upgrade and there is 2008B map on the CD, and you have to update both firmware and map.
Dec 27, 2008 | Sony NV-U73T GPS Receiver
Garmin c510 no maps
You're unit is probably missing the gmapprom.img file (due to the failed update maybe?).
Try contacting Garmin - if you've got registered maps they may send you another copy (although big file - 100+MB)
Nov 19, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Won't let me go to main menu
You should have had a map backup cd in the box. Put the cd in your computer and connect the myguide to the computer by usm this will allow you to add/remove maps
Nov 17, 2008 | MyGuide 3240 GO GPS Receiver
My StreetPilot c330 unit says ?Can?t Unlock Maps? when I power it on. What is the problem?
My Streetpilot c330 and it says? can't unlock maps? How can i fix this problem.
Oct 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Teletype Gps WorldNav 3100 Deluxe Portable GPS GPS Receiver Logo
163 people viewed this question
Top Teletype Gps GPS Experts
Will Halftowaite
Are you a Teletype Gps GPS Expert? Answer questions, earn points and help others
