Question about Krups XP 4000 Espresso Machine
Pump makes strange staccato sound at 1 second intervals. A little coffee dribbles out. Then it just shuts itself off. Seems to be a pressure problem?
    President:
  • 1,618 Answers
Check the grind on the coffee or the packing pressure used to tamp. If it flows great without coffee in the portafilter, then the problem is the grind or tamp. The grind might be too fine that the pump has to use so much pressure that the relief valve open and most of the water goes into the drain tray.
Posted on Jun 30, 2009
How can i tell if my fuel pump is bad?
old post, but Ill answer this , as it seems most forums give bad advice. on this topic.
answer,. read the FSM , or alldata.com or suzuki pit stop plus
it shows 6 tests.
this car came with 2 diff. engines, G16b and J18.
and the tests are simular but data is different.
here are the tests in the FSM.
1: cranking pressure. 35 to 40 psi. this is a guess. no engine stated, so no real numbers... answered. only a guess.
2: running pressure (vac. drops it) drop about 6PSI running.
we now test the FPregular for proper reg. at 3 vacuum points. (a hand vacuum tool)
3: the shut test.
4: the leak down test.
5: the 4 tests for INJECTOR leak down tests. 1 by 1>
its really 8 tests.
now the shade tree test
fuel dont leak from rail, fitting cracked, cranking , pump dead
or lost 12vdc to pump cranking.
that be it, with no gauge. must DIY fail here if the fitting dribbles.
as dribble tests dont tell you if pressure is correct.
a carb can run on 0.1psi or gravity , only
but on EFI it takes, 28psi, min. (injectors makers rule , no mine)
Jun 25, 2014 | 2002 Suzuki Esteem
Leaking water under the drip tray
First, be sure to regularly push a straightened paper clip in that nozzle! It can get clogged with coffee grinds quite easily.
Then call Sunbeam and tell them you want the waste chute extender. It's a little plastic tube that fits over the nozzle to extend it further into the drip tray. Truth be told, you could probable push a 2cm piece of 3mm aquarium pump air tubing over it.
May 22, 2013 | Sunbeam Coffee Makers & Espresso Machines
When pressing the "start/stop' button
the pump is not getting water, make sure it does
Nov 11, 2017 | Nuova Simonelli Mac 2000 I Group Espresso...
I have been having trouble with the coffee coming out (vvery slow flow) so I descaled the machine today. Now its worse - it is just dribbling out - doesn't seem to have enough water going through. Can you...
2 things can cause this.
1. the grinder is set to fine abd you are creating to much pressure and the pump is having a hard time pushing water through.
2. You are getting a blockage in the brew head from coffee residue and oils.
Tru pushing the prre grind button and making a coffee without putting any coffee in. Blank shot. If it works its you grind. If not its your brew head. Needs to be cleaned.
Oct 03, 2010 | Saeco Royal Professional Espresso Machine
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Mar 24, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
B-50
the needle in your k-cup holder is broken and over presure built up in the k-cup, and create security stop. Change our k-kup holder. if the needle is still in place the k-cup must be puncture on both side on top and bottom. if is right our needle can be block. clean with a little rod of stainless steel.
Nov 03, 2007 | Keurig B50 Coffee Maker
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Jul 29, 2007 | Karcher 2500 PSI Pressure Washer
Coffee Makers & Espresso Machines Logo
436 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
