Question about Microsoft Xbox 360 Console
No signal on tv
No signal message on tv screen bought new leads inc hd still same.
  • 51 Answers
If you have the reciept you may be able to send it into microsoft and get it replaced/fixed.
Posted on Jul 10, 2009
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have a Bose 3.2.1. GSX Series 3 system. Recently, when playing DVD's I am getting sound only and a message on the TV screen saying 'No Signal' and on the 3.2.1. display 'communicating with your TV'....
Possible faulty lead or a poor connection. Has the new Sky Box been fitted to the HDMI socket the Bose had? Try switching sockets if there is more than one HDMI socket.
Jun 02, 2017 | Bose 321GS Series II System
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
I have a vizio vw32L40a and the screen is too wide. there are only wide and stretch settings, no normal setting. the screen is too wide for the tv.
6/09 I had the same problem when receiving the signal over the air with the input set to TV. Perhaps the signal strength or type was varying. At any rate, after I hooked up HD cable and watch from that input, the problem no longer occurs.
Jun 27, 2009 | V, Inc. Vizio P50HD Plasma Television
Initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Jun 22, 2009 | Initial Televison & Video
Actually it a lnt5271f, but...
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
Jun 09, 2008 | Televison & Video
Hdmi to dvi
This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
Mar 28, 2008 | Computers & Internet
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Bought a new 42' flat - "No Program or Weak Signal"
Hi,you have not said weather you are using a scart lead(euro connecter)or an RF lead,if you are using the later don't,please connect the vcr to the tv via the scart to scart euro connecters,use a good quality scart lead(the thicker the better)as the thicker ones generally are 21 pins connected meaning it should be auto switching so as soon as you play a tape it will come straight on.
Feb 02, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
66 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
