Home | D-Link | DI 514 Wireless Router (DI-514) | How to Connect Sony Vai...
D-Link DI 514 Wireless Router
Problem for D-Link DI 514 Wireless Router (DI-514)
How to Connect Sony Vaio to Wireless Network
By cbrooks9 on Jun 28, 2009
I have a Sony Vaio (Windows XP) that I want to connect to my wireless network - which is a D-Link DI-624. We recently reloaded the Sony with the operating system and obviously removed the program needed for receiving the wireless feed (it worked fine before reloading the Sony). What do I need to do ?? Thanks
Clarification Request
Posted by niquose on Jun 29, 2009
Check first if the wireless card drivers are installed properly Hit on Windows and Pause Break key simultaneously. Click on Hardware Tab then Device Manager Click on the plus sign under network adapters and verify that there is a wireless card listed there with no red x, question mark, and exclamation point. Double-click on it and check the device status if it says "This Device is Working Properly". Let me know if this is the case on your device manager so we can proceed with checking your wireless settings.
Solution #1
posted on Jul 12, 2009
Somewhat Helpful)
mail2pvs
Rank: Guru
Rating: 87%, 290 votes
hi
there are a few steps involved
1. check to see the ip address provided to you by the ISP and group your ip address range to the same range
2. check to see if you require any DNS server addresses
3. check to see when the router is connected at the internet port from the modem then is it having signal at the port numbered 1 only or is there no signal at all ports 1-4
4. if there is signal at port1 but not on other ports then instead of connectng the cable from the modem at the INTERNET port connect it to port1 and it will be distributed to all the ports 2-3 also there will be wireless connectivity too
cheers
Pls rate if this was any help
Was this helpful?
Yes
No
Popular Solutions for D-Link DI 514 Wireless Router
Questions and Unsolved Problems for D-Link DI 514 Wireless Router
Do you recommend D-Link DI 514 Wireless Router (DI-514)?
Answer
Answer
Old airport card required short protocol. Now it needs me to reboot router about once a day.
Answer
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem... (More)
Answer
Wireless router works when wired but does not work wirelessly.
Answer
I have connected d-link 514 by the direction but my computer will not recognize
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link DI 514 Wireless Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1504
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
